01-07-2010, 09:59 AM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Greer
| tips
im 15 years old and ive been around crawling for maybe 2 years.i have a losi 1/18 mini rock crawler,what can i do to make it better with out spending tons of money i just ordered have medal diff gears ,whell weights,30 deggree long arms and 1.9 losi basher tires bigger chassie plates and some other littel stuff this morning
01-07-2010, 10:03 AM | #2 |
Newbie Join Date: Dec 2009 Location: cali
reading this thread helped alot The beginers guide to the MRC. for upgrades Losi MRC Ultimate Guide basically,what i've done to my car was cut the electronics tray out, moved electronics as low as possible, wheel weights, shock oil,limited the shocks,etc. basic things,and it crawls better..better tires will probably make a night and day difference for me,because sometimes it wont crawl over simple things |
01-07-2010, 12:08 PM | #3 |
thanks fo the links and the stock tires just suck
01-07-2010, 01:32 PM | #4 |
Pebble Pounder Join Date: Dec 2009 Location: England
i guess you could try and get a new motor i am just about to by one and i know its hard to find new motors for it but if you can thats what i would go for also you can get high clearence links a new bodyshell for more clearence. Ive just noticed they have some 1/18th brushless motors for 50 us dollars which in british pounds isnt much.(from england) Hope this helps also is it stock |
01-07-2010, 03:11 PM | #5 |
o thanks and not for long i just orederd, grappler body,medal dif gears,wheel weights,v2 mrc skuklz chassie plates ,30 degerrie long arms and some 1,9 basher tires
01-08-2010, 03:12 AM | #6 |
just seen some batterys with more aH that might make it have longer last time on the truck also when or if you get the brushless motor you might need a new esc there are some at hobbywing with a rock crawler mode i dont really now much about the mrc so i dont know if that is a good idea.
01-08-2010, 06:27 PM | #7 |
Rock Stacker Join Date: Dec 2009 Location: salt lake
are you making it a four link. it helps a tun |
