01-16-2010, 11:06 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: CA
| Is the stock motor timing set at 0 degrees?
I have done a search and read the sticky but I still can't come up with a straight answer. Does the stock motor have positive timing or is it set a zero? Is there any difference when running the motor in reverse? thanks
01-16-2010, 11:47 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
It's set at 0. Forward and Reverse have the same speed.
01-16-2010, 11:58 AM | #3 |
That is what I needed to know, thanks for the help.
01-16-2010, 04:09 PM | #4 | |
Pebble Pounder Join Date: Dec 2009 Location: North Wales
| Someone far wiser than me says: Quote:
If your thinking of flipping the tranny round then this should put you off till you have a spare motor to throw in when the stock one dies. | |
01-16-2010, 05:28 PM | #5 |
Is there any other hardcore evidence on the timing? I have searched and found just as many post saying it is zero as saying it is positive.
01-17-2010, 07:37 AM | #6 |
Quarry Creeper Join Date: Nov 2009 Location: San DIego
my dads motor seems to run faster in reverse, and thats with 2 different radios so I dont think we had a setting wrong
01-17-2010, 10:01 AM | #7 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
THE TIMMING ON THE STOCK MOTOR IS ADVANCED. PERIOD. as for your dads running faster in reverse, if he has his motor/tyranny flopped, then he has either flipped his wiring, or flipped the switch. Either or... Doesn't matter, of your motor is flipped the its going to be faster in reverse, because technically that is forward |
01-18-2010, 07:25 AM | #8 |
01-18-2010, 07:31 AM | #9 |
MRCnoob - Give it a try and let us know if it helps, won't do any harm to try.
01-18-2010, 10:30 AM | #10 |
Newbie Join Date: Apr 2009 Location: Auburn
Huh?
