02-26-2010, 08:15 PM | #1 |
Newbie Join Date: Dec 2009 Location: monroe, nc
| need a little help here
i just bought a slider motor for my mrc, and when i punch it, it stops for a few seconds then is normal again? i have a bec, 645 srvo, and a sidewinder micro esc, and the losi battery that came with it. the servo turns every now and then also when i punch it
02-26-2010, 08:22 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Rebind your reciever and transmitter, and all will be well. Also, replace the tx batts |
02-26-2010, 08:43 PM | #3 |
ok, i put new batts in the transmiter, when i try to bind the light on the reciever just stays green, the orange one wont come on
02-26-2010, 08:48 PM | #4 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
| try reading the manual lol |
02-26-2010, 08:52 PM | #5 |
im not a idiot, i read the manual, and i see u live in mooresville, im in monroe.
02-26-2010, 09:19 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
sounds like a bec problem to me.... but idk
02-26-2010, 10:10 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
I'm having issues with a new sidewinder micro esc I just installed. Is yours doing this: Sidewinder micro help please. |
02-26-2010, 10:16 PM | #8 |
Pebble Pounder Join Date: Feb 2009 Location: Hoodsport
yo beaver i had the same problem after i put my bec in and it was the stock battery was bad got a new stock one and now it works just fine.
02-27-2010, 09:30 AM | #9 |
ok, i have a battery out of a slider ill try that
02-27-2010, 03:48 PM | #10 |
ok tried that, fixed everthing but the wheels still turn wen i punch it, what would taking the bec out do? it had one in it when i got it so idk what exactly it is for.
02-27-2010, 03:54 PM | #11 |
I was just having the same issue with the steering twitching when using the throttle. I had my BEC wired to supply power to the servo only and not the receiver. I just changed the wiring so that it is wired according to the diagram on CC's website and now everything is working fine. Not sure how yours is wired but I just thought pass what I did along.
02-27-2010, 04:50 PM | #12 |
i just looked at the thread u had started, mine is like the diagram that "crawl before walking" posted.
02-27-2010, 05:14 PM | #13 | |
Yeah that's the way I had mine wired. Try disconnecting your bec all together and try running it and see if the problem goes away. If it does then re-install the bec according to this diagram: http://www.castlecreations.com/produ...ec_wiring.html | |
02-27-2010, 05:16 PM | #14 |
man I had the same thing happen while back on my sond axial ht 645 servo.cc bec and a sidewinder servo worked good at a stand still give it full throttle and the wheels turned all the way to the right. I blamed it on a bad servo motor. I put in a jr 9100 and all was good. sure is frustrating though. |
02-27-2010, 06:31 PM | #15 |
yes very frustrating, ok, i took the bec off and it seems to be fine now, will it be ok to not run the bec? or is it necessary?
02-27-2010, 07:01 PM | #16 |
i would run it with the bec if you are using a full size servo cause the servo will draw alot of power away from your motor so when you turn and need to gas it, you wont have the wheel speed that you would need.
02-27-2010, 07:07 PM | #17 |
02-27-2010, 07:15 PM | #18 |
ok, thanks, seems to be working but i wont know for sure until i get my metal lockers, i didnt even get to the rocks before i stripped a locker,lol
