04-02-2010, 07:17 PM | #21 |
Rock Crawler Join Date: Feb 2009 Location: LaGrange
where do i get one of these here chassis???
04-02-2010, 07:33 PM | #22 |
RCC Addict Join Date: Feb 2007 Location: LRC
04-02-2010, 07:35 PM | #23 |
Rock Crawler Join Date: Dec 2008 Location: dallas
04-02-2010, 07:51 PM | #24 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
04-03-2010, 09:22 AM | #25 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
04-19-2010, 11:50 PM | #26 | |
RCC Addict Join Date: Jan 2005 Location: Germany north
and your runtime withthe 325īs ? | |
04-20-2010, 10:01 AM | #27 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
It performed great this weekend can not wait for mine.
04-20-2010, 11:38 AM | #28 |
Quarry Creeper Join Date: Oct 2008 Location: In the basement...
| I was using about 60mah from them with a 5955TG and a mongoose system on a 3-4minute run.. So i'd say you could get comfortably 12-15mins with the 2S 325mah 45C. Not to jack your thread but this was mine... The only change I'd recommend would be changing the front top plate to allow for OTA steering - I had to make a custom plate and shorten the front upper links to allow for the OTA steering link... I also changed some of the spacers to make it symetrical... This has it with the 880mah 2s Polyquest batteries but for competing I run the 325mah 45c TP packs I now have the LCC outdrives with felsenfest knuckles for amazing steering.... Last edited by Arct1k; 04-20-2010 at 11:45 AM. |
04-22-2010, 12:41 PM | #29 |
Rock Stacker Join Date: Jan 2010 Location: Greer
| wow |
04-22-2010, 04:26 PM | #30 |
Newbie Join Date: Sep 2008 Location: wichita
i want one |
04-24-2010, 04:02 PM | #31 |
| 1229 in grams and around 10min Well pulled a 3rd at ECC. The truck handle great i just needed more wheel time with the 1.9. I keep hitting the dig switch and nothing. |
04-24-2010, 04:19 PM | #32 | |
This is just my opinion but when you make a OTA steering you loose steering by the looks of it and you half to raise the servo which make's you have a higher CG. I gained 2-3 degree's on the ramp when i lowered the servo. I did change the tie rod to delrin that way i can just ram it into the rock and get the front up and over just about anything. | |
04-24-2010, 05:49 PM | #33 |
When T1E finally finishes the test period gonna mail my mini out to you for some super tune upgrade setup lolol. Rig looks great brother and judged it on one course ad it was a beast!!!!! |
04-24-2010, 08:40 PM | #34 | |
I didn't have to raise it but didn't lower it although I might have some room to... Its changes a bit from here with the new knuckles - I'll grab some pics for you tomorrow... Cheers | |
04-25-2010, 10:06 AM | #35 |
Sorry for the bad pics but here is current setup... I was able to lower servo about 4mm... |
05-11-2010, 11:45 PM | #36 |
05-11-2010, 11:46 PM | #37 |
05-11-2010, 11:49 PM | #38 |
05-12-2010, 06:27 AM | #39 |
05-12-2010, 09:00 AM | #40 |
Not Bad????? Thats impresive......
