10-13-2010, 06:22 AM | #61 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
10-13-2010, 12:07 PM | #62 |
RCC Addict Join Date: Mar 2009 Location: Chilton
11-24-2010, 11:27 PM | #63 |
Front driveshaft yoke at the trans,what are you using?
11-25-2010, 07:39 AM | #64 |
AKA 2G's Join Date: Feb 2006 Location: Where the wind blow's
Im just running MIP drive shaft's. |
11-25-2010, 11:18 AM | #65 |
Mip's are heavy aint they. The pics in your 1st post,on the spur side of the trans,what is that I'm looking at. Looks like a stock mrc yoke fitted to something else. |
11-25-2010, 09:29 PM | #66 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
| The MIPs do not weigh that much maybe twice as much as the stock drive shafts. Well worth the money.
11-25-2010, 09:35 PM | #67 |
11-25-2010, 10:44 PM | #68 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
11-25-2010, 10:59 PM | #69 |
Quarry Creeper Join Date: Mar 2009 Location: searching
11-26-2010, 08:10 AM | #70 |
| I just cut the stock drive shaft and put it inside a ped shaft then pinned it with a screw. The ped shafts are to big around and hit everthing plus thay are alittle heavyer if you use steel yoke's.
11-26-2010, 09:21 AM | #71 |
I've seen other people break them, but I've been running the same set of stock shafts for 2 full seasons of local comps plus Motorama and ECC and many many more practice days and have yet to break a stock drive shaft.
11-26-2010, 11:15 AM | #72 | |
My past mini I never broke a shaft. I'm now running the blue can holmes motor on a 350mah 3s and I snapped a stocker on the first course around gate 7 like it was a toothpick. So I picked up some MIPs. | |
11-26-2010, 11:36 AM | #73 |
| I was gonne pick up a set at my lhs once. But when I had them in my hand they felt heavy.
11-26-2010, 01:01 PM | #74 |
11-26-2010, 01:15 PM | #75 |
11-26-2010, 01:57 PM | #76 |
You are only adding 10 grams from the stock shafts, and twice the strength. Some things we just have to sacrifice.
12-19-2010, 05:08 PM | #77 |
After make a new chassis for my 2.2 and had to make a new one for this one too.
12-19-2010, 05:15 PM | #78 |
Nice work! Are those barrell nuts on your front axle? New 4340's perhaps??
12-19-2010, 05:22 PM | #79 |
12-19-2010, 05:43 PM | #80 |
