Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Triangulating Lower Links
Old 10-26-2010, 03:39 AM   #1
Default Triangulating Lower Links
Hi Guys
My new MRC arrived in the mail today from the states.
Im wanting to triangulate the lower links. Is there a vendor that makes one to fit the standard chassis? (I did try searching) Or if you have modded the standard skid, show me some pics. Thanks
kizzo is offline   Reply With Quote
Old 10-26-2010, 04:58 AM   #2
Return it . Right away, and buy the losi mrc PRO raceroller.Thats the best advice your gonna get. I have the gc3 chassis its great ,the pro is just alot lighter. So if you cant return the stock mrc for the pro then just by the gc3 .. Good luck
droopmodmrc is offline   Reply With Quote
Old 10-26-2010, 04:51 PM   #3
X2 ^
dickwart is offline   Reply With Quote
Old 10-27-2010, 07:00 AM   #4
Are you building another scaler Kizzo ?
RiZZa is offline   Reply With Quote
Old 10-28-2010, 12:41 AM   #5
I dont think this one will be a scaler. Just a crawler.
I think im going to try and mod the standard skid to triangulate the lower links. I think I have a plan. I will post up pics when I have it done.
Old 10-28-2010, 12:45 AM   #6
If you dont already have 4 links setup you should do that.
SMR 510RR is offline   Reply With Quote
Old 10-30-2010, 04:44 AM   #7
Well I decided to leave the stock skid alone. Just incase my mod did not work. So I made a skid from parts I had laying around. Now it does not look the prettiest from underneath. But how often do you see that.
Seems to work good. Now I just need to get my rear 4 link done. I just need to get some longer m2 bolts so I can move the shocks out wider. My arms would always hit the shocks, so just running the A frame for now.
Old 10-30-2010, 12:25 PM   #8
Nice work, glad you got it sorted. Looks like a decent job too
neiloid1 is offline   Reply With Quote
Old 10-30-2010, 11:41 PM   #9
I like the setup! Much improvement over stock?
crazyracer is offline   Reply With Quote
Old 11-02-2010, 11:21 PM   #10
I am interested in getting a little more info on the parts (or scraps) you used to do that mod. I have a stock width DMG chassis, and I've been kicking around alternative modifications to triangulate the lower links using the stock skid.
In case it helps you, here are two threads on this forum that have attempted to triangulate the lower links using the stock skid:
triangluated lowers on stock skid plate...
My Losi Mini Crawler pics and vid [see post #18]
matthen is offline   Reply With Quote
Old 11-09-2010, 06:55 AM   #11
WOW! To think, for the last few months I have been fighting just the top links! This is brilliant, good thing I have that chunck of delrin floating around!
oregonfear is offline   Reply With Quote
