07-07-2011, 12:34 PM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: Austria
| Thunder-Worm with LCC Axles...
Hi guys! Here is my entry to the 1.9er comp world - my little Thunder-Worm with LCC axles Here a little review from beginning to yet: The tranny is made by myself: Also the wheels are homemade: The knuckles are a mix of Felsenfest AX10 knuckles and a little bit homemade: At least i´ve shorten the axle to fit it for the 1.9 class: At the moment i´m waiting that the postman bring my MiniJuice chassis to me... to be continued... With best regards from austria, Gerry |
07-07-2011, 12:49 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
if you can come up with a successful steering link for that kind of degree, that will be dangerous as hell! |
07-07-2011, 12:50 PM | #3 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
Very cool! now this is a true build thread I'm keeping my eye on this
07-07-2011, 12:52 PM | #4 |
Looking good Gerry! I will get those measurements for you this evening when I get home from work! |
07-07-2011, 12:56 PM | #5 | |||
07-07-2011, 01:49 PM | #6 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
TOTALLY impressed! This has the potential to be great! |
07-07-2011, 02:13 PM | #7 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Hi Your build is looking good and I'm jealous of your homemade parts... For sure, I'll follow your thread hoping you'll be luckier than me. I also wanted to go that route with the Y-Town minijuice but my order got lost on the way to my house (Still waiting for Jeremy to get some refund from USPS - 75€ -) and I had to change my plan . Maybe I'll reorder one or choose another bodyless chassis when I'll get tired of the bug I have now... Have fun dude , Emmanuel |
07-07-2011, 02:20 PM | #8 | |
I´ll hope you´ll have luck and all went perfect I can´t wait to get this great chassis to continue my build With best regards from austria, Gerry | |
07-07-2011, 07:31 PM | #9 |
Pebble Pounder Join Date: Feb 2010 Location: nunya dambidness
How much did you cut out of the LCC axles. Maybe some pics if we could???
07-08-2011, 12:46 AM | #10 |
07-08-2011, 01:04 AM | #11 |
That would be great thanks |
07-08-2011, 01:52 AM | #12 |
Let´s start us shorten axles At the front axle you only have to cut the axle each side about 6mm: IMG_3877.jpg IMG_3878.jpg Then cut the CVD´s, welding or braze them to the right length and your job is done! IMG_3879.jpg On the last pic you also can see that i have exchanged the LCC CVD Joint to an Axial CVD Joint - so i had a real cool steering angle... Now let´s do it on the rear axle - it´s a real bit more tricky: Here you don´t have to cut anything on the axle! IMG_3880.jpg IMG_3881.jpg You have to shorten the "end caps" from the axle: IMG_3882.jpg When you have cut these round about 7mm each side (or more if you want) you have to mill out the caps that you can mount it again: IMG_3883.jpg I do that with the Dremel... Than you shorten the driveshaft: IMG_3884.jpg Mount the longer distance and the other stuff, mount all and you are finished! IMG_3885.jpg IMG_3886.jpg With best regards, Gerry |
07-08-2011, 01:56 AM | #13 |
Ummmm.... Something is going wrong with the pics.... |
07-08-2011, 07:01 AM | #14 |
07-08-2011, 07:27 AM | #15 |
Looks great Gerry, If you ever have any questions about the LCC to MRC shoot DLUX a PM he did something like this also. I would like to see yours up and running. Subscribed |
07-08-2011, 08:29 AM | #16 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Gerry- Have you run this rig yet or is this your axle work in progress? I know Dlux had some issues getting the tranny to work right and give him the wheel speed he wanted due to the gearing of the work and such. I would love to know if you have had any issues on your end. RickM |
07-08-2011, 09:12 AM | #17 |
Hey Rick, At the moment i've been waiting at the chassis, but i want test today evening this setup with the components i've here. We will see how it works, i would take an video of the testrun... Gerry |
07-08-2011, 01:03 PM | #18 |
Today i´ve started the first test with the homemade tranny and the LCC axles. This are the components: 2S LiPo 30T handwound motor from RCBM-Scaleparts with this specs: 14025rpm / 7.2V / 77W / 95Nmm http://www.youtube.com/watch?v=8cze66gXopU Tomorrow i will test it on 3S - and my feeling said - that looks good Gerry |
07-08-2011, 09:25 PM | #19 |
With the home made tranny, you might be able to get around any tranny related wheel speed issues. I certainly will be watching this build as the durability of the mrc is always concerning.
07-10-2011, 08:46 AM | #20 |
I´ve decided to continue the build with an homemade chassis like my old RollerCoaster Chassis for the AX10: So i´ve room enough for tons of steering and more ground clearance More pictures and infos comes later... |
