08-03-2011, 07:11 PM | #1 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
| Better rod ends?
I'm probably fartin' in the wind here, but I'm tired of breaking those danged tiny PITA lower link rod ends. Does anyone know of a better option (aluminum, better plastic, or.............)? It's always at the axle end where I break them, and there just doesn't appear to be enough material on the ears to drill them out to M3 (I'd rather break the rod end than the axle casing).
08-03-2011, 08:03 PM | #2 |
If it pans out this could solve all your problems. Feeler thread 53 Willys is working on it now. You could do a Traxxas 1942 rod end of if your links can support it you could even do a Revo end. |
08-03-2011, 08:08 PM | #3 |
I'll keep on eye on that!
08-03-2011, 08:16 PM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
From what I can tell so far this is gonna be a awesome setup....I'm trying to get away with only running the link mount ring...doing just the link mount will make it so you can adjust caster and still adjust link/shock position too...not to mention you can widen up the shock spread at the axle and the links... I pretty pumped to get out and try it.. Nice work and idea Erik! |
08-07-2011, 03:45 PM | #5 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
Any more movement on these things? I am about to build up an L-trail MRC scaler and this would enable me to mount the shocks outside the frame rails. Do you have an ETA on when we might see these in your store, Eric? Also, will they work on the rear axle?
08-07-2011, 07:01 PM | #6 |
What about the 1/16th revo ends? I will also be working on my Dlux mounts soon... |
08-07-2011, 07:31 PM | #7 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
How are you breaking the rod ends before breaking the axle mounts? I dont think I've ever broken a rod end, but I have broken the link mounts and the only thing that has broke in the last 2 years are my Pro c/f chassis and the upper front link mount.
08-07-2011, 07:46 PM | #8 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
I run TT links with tmaxx ends |
08-07-2011, 08:17 PM | #9 |
| Just lucky I guess! I'd MUCH rather break the rod end instead of the mount any day. I've managed to break 2 so far, 1 at the State Crawl-Off, and one the other day while practicing. Two isn't bad, but one of those could have cost me dearly!
08-07-2011, 08:18 PM | #10 |
08-07-2011, 08:20 PM | #11 |
08-07-2011, 08:58 PM | #12 | |
BTW, I cant recall ever breaking a stock MRC rod end... | |
08-07-2011, 09:49 PM | #13 | |
If you want, I can sell them when the adapters are ready. You just have to be willing to take the chance that they do not work. Its either that or wait until they are tested. | |
08-08-2011, 01:48 PM | #14 | |
| Yes. Quote:
And I've never seen it mentioned anywhere: do these work on the rear axle as well? | |
08-08-2011, 02:50 PM | #15 |
I agree. The axle mounts and more so, the tiny, sloppy rod ends have to go. Sorry I missed your question before. No, they are not designed to work on the rear axle. The MRC axle is not too friendly to build parts for since nothing is round and true. I can work on it if there is some interest though. Maybe it would just be as simple as using the same shock mount I already designed and making a different ring to go around the lockout. At that point, I might have to look at making my own lockout and rear knuckle weights. |
08-09-2011, 10:36 AM | #16 |
| I think I found a solution for the rears
Eric, I think I came up with a solution for the rear link/shock mounts. It's little more than a 1.5mm thick aluminum plate with a bunch of holes and a couple of notches cut into it. It would be secured using the existing extrusions and link tabs (well, only the tabs used to originally used to secure the links to the axle) on the axle and wouldn't require any modification to the axle housings themselves. Here is a rough drawing. It's neither drawn to scale, nor have I made the exact measurements needed to cnc it, but you'll get the point. And it would slide nicely between the rear lockout and outer link attachment tab. This plus your front link adapter and chub/knuckle mod would allow for the the use of the L-Trail chassis with a rail spacing of 65mm with the shocks mounted outside of the frame rails. What do you think? Last edited by pixelnate; 08-09-2011 at 11:41 AM. |
08-09-2011, 11:40 AM | #17 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
That looks like a great idea.
08-09-2011, 11:56 AM | #18 |
| I think youre trying to sucker me into making the rear link mounts Your idea has some good ideas in it. 1.5mm is close to .060 and I dont think I would trust that as far as strength. I am also not sure how I would feel about the whole thing being held on by one 2.5mm bolt. Like I said though, it has some good ideas behind it. Like everything, it just needs some work. I will see if I can take a look at it sometime soon. I have way, way too much on my plate today. |
08-09-2011, 01:40 PM | #19 | |||
Sure thing. | |||
