09-03-2011, 07:27 AM | #1 |
Rock Crawler Join Date: Jul 2011 Location: north little rock
| Is the sound my axles?
Under a bind I get a clicking sound on my Losi Pro. It sounds like something get stripped out. I've watched the spur and pinion (both still plastic) and it's not coming from them. Any ideas on this? Side note, added rear bent links and can't believe the difference. |
09-03-2011, 09:26 AM | #2 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Probably. Mine did that in the rear axle; I took it apart, shimmed the gear, and put it back together using through bolts and nuts. That took care of it.
09-03-2011, 04:56 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
hold the rig down with your hand, throttle it a little. makes the sound, its your trans. if is quiet till it moved, its the axle. check my build thread to see how to make mini beef tubes to remove slack in the side to side of the diff.. i still use my cheap "stethoscope" that helps find chattering engine valves, for these little boggles. |
09-03-2011, 06:02 PM | #4 | |
09-03-2011, 06:07 PM | #5 |
| BWD Mini Wedge with Dub Topper build there's my mrc thread. I stumbled upon the idea when a section of tubing was laying at the axle, and it fit perfect. with my lcc axle swap, they are in the way, but with stock mrc parts, they fit fine, and add a little strength and weight to the axle housings. i had used them to squeeze the locker against the pinion gear. |
09-03-2011, 06:11 PM | #6 | |
