03-17-2012, 07:14 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: SW Iowa
| comp tire height?
Got a mrc to comp with, first one I've had. Got several different tires,and noticed that some were a lot taller then others. The rovers, chisels, rock claws were small compared to the flat irons, rock crushers. I just figured all 1.9 tires were the same size. What are people running in comps? The smaller tires have good reputations, but looked really small compared next to the taller tires.
03-17-2012, 07:58 PM | #2 |
Newbie Join Date: Mar 2012 Location: PNW
| Re: comp tire height?
Glad you asked just about bought the flat irons today, but wanted to here what others were running and why. I am new to the crawler world |
03-18-2012, 09:10 AM | #3 |
Rock Crawler Join Date: Oct 2011 Location: minot
LOVE my rovers.. i run pinks just because... |
03-18-2012, 10:47 AM | #4 |
Pebble Pounder Join Date: Oct 2009 Location: Rittman
When it comes to tires a lot of it depends on the rock type and terrain you run on. Different tires work better on different terrain. You just have to figure out what works for you. Now for comps. The max tire size is 4.25". The pro line flat irons come in right at that size. So if you plan on comping keep that in mind. Also there is tires made for 1.9 class that is even larger like the mickey Thompson claws. I think they are 4.75". They are mostly used to run on 2.2 class scale rigs. Right now I have hb rovers on my comp set up. They hook up great. There are times when I wish they were just a tad larger.
03-18-2012, 01:16 PM | #5 |
Rock Crawler Join Date: May 2007 Location: Arnold
The stock rock claws work O.K but I cut and siped mine and they worked so much better that I have'nt botherd to put the rover on the MRC and probly won't untill the claws ware out.
03-18-2012, 05:10 PM | #6 |
Quarry Creeper Join Date: Nov 2010 Location: Atlantic
The rovers do a great job for comping. Where are you gonna comp, the Plex?
03-18-2012, 05:12 PM | #7 |
| Re: comp tire height? |
03-18-2012, 08:45 PM | #8 |
| Re: comp tire height? I use a small GYROs saw blade on my dremel to make the slits in the tred and side cutters to take the small center tred out.
comp tire height? - Similar Threads | ||||
Tamiya f-350 tire height | jon1197 | Tires and Wheels | 2 | 10-23-2011 07:29 PM |
tire height? | dynamaxxed | WRCCA Rules | 2 | 02-13-2011 01:50 AM |
Tire Height Measurement | binaryterror | WRCCA Rules | 1 | 11-24-2010 12:46 PM |
tire height? | losilover | Non Crawler RC's | 0 | 04-28-2010 04:50 AM |
ideal 1.9 class tire height? | dieselfuel | Tires and Wheels | 9 | 11-18-2008 08:47 PM |
