03-27-2012, 12:05 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Grand Junction
| Mrc lipo upgrade suggestions
Aright first off I'm Robert. Not a big RC guy had an rc-10 buggy about 10 years ago and have had my mrc for about a year. Just getting back into it. Already has lowered electronics, wheel wideners, bent links, axial 1.9 beadlocks, and proline flatirons. Just ordered a GC3 chassis and a new body for it yesterday. Was wanting some suggestions on which way to go as far as a lipo setup for it. Won't be Comping it as of yet. I mainly use it in my back yard on the course I setup. Maybe in the rocky areas on the outskirts of town. Right now all of my electronics are stock. I plan on upgrading to the hi-tech 645 servo and maybe an over the knuckle steering setup. Can't afford to do an escape and motor right now. Any input would be a great help and thanks in advance! |
03-27-2012, 12:26 PM | #2 |
| Re: Mrc lipo upgrade suggestions
Forgot to mention that I don't want o break the bank on a battery/charger setup.
03-27-2012, 08:11 PM | #3 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
check out hobbypartz.com for charger (thunder ac 6 about $45) and they have all kinds and sizes of lipos.
03-27-2012, 08:28 PM | #4 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
X2 on the AC-6 charger; of the 3 I own, it is by far my favorite. I have used several Hobbypartz batteries as well, and have always been pleased.
03-27-2012, 09:00 PM | #5 |
Ok thanks. Looks like a great charger for the money. What size lipo do u suggest? Any other accompanying parts I will need?
03-27-2012, 11:00 PM | #6 |
Rock Stacker Join Date: Feb 2006 Location: Ringgold
I too have the Thunder AC6 and love it. Get a LiPo in the 800mah - 1300mah range. Anything smaller kills the runtime and anything bigger is shaped like a side x side 2/3 A pack. Personally I like the Sky Lipos. Also, no bigger than 2S. 3S will burn everything up.
03-27-2012, 11:46 PM | #7 |
RCC Addict Join Date: Nov 2007 Location: somewhere
Here's a link to the ones I use mounted on the upper front links Sky Lipo 800mAh 7.4V 40C for 800mm RC Planes and Blade, Walkera, Esky CX Helicopter |
03-28-2012, 12:10 AM | #8 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Mrc lipo upgrade suggestions Quote:
On my MRC I run Thunder Power 325mAh 2s packs & get anywhere from 10-15 mins of runtime. Granted...my mini is strictly a comp rig so 6 mins is all that I NEED but the size is great for a mini setup. They're inexpensive as well. I Its all personal preference but I suggest running the smallest pack ya can. It makes mounting location & switchin em out so much easier than fumbling with a larger pack. J.D. | |
03-28-2012, 07:15 AM | #9 |
HardKnockz- thanks for the input! I would like a little more runtime out of the batteries than 10-15 minutes. Is only a backyard crawler right now. I'm not even sure if they comp these in my area. I know the 2.2's are fairly popular around here. What are you guys running for a cutoff on the stock esc?
03-28-2012, 07:18 AM | #10 |
Juggalo- the link you sent me is for a 800mah 2s lipo but it is a 40c and I thought there was no bennifit in going above a 20c on one of these?
03-28-2012, 08:18 AM | #11 |
I run 40c for the punch in my opinion there is a.diff between a 20c and a 40c when it comes to the punch.
03-28-2012, 08:24 AM | #12 |
Even if there wasn't a benefit...can you really beat the price of the 40C???
03-28-2012, 08:34 AM | #13 |
40c on a mini IS fun. I ran my TP 850 3s packs for a comp after leavin my little guys at home & I had fun jumpin stuff instead of crawlin. Like I said...its all preference & use in the end. What I like some dont & vice versa. J.D. |
03-28-2012, 10:38 AM | #14 |
Ok thanks guys. Ill try that setup out. What do u reccomend since I'm using stock electronics for now?
03-28-2012, 10:45 AM | #15 |
I ran the same batt in link with stock esc and motor in my mrc
03-28-2012, 11:51 AM | #16 |
Do you have to wire anything differently? Also I notice that there is an extra pigtail commingle off the lipos in the pictures. What is that for?
03-28-2012, 12:10 PM | #17 |
| Re: Mrc lipo upgrade suggestions |
03-28-2012, 12:23 PM | #18 |
If your just bashing - 1300mah 2S is a good size with excellent run time.
03-28-2012, 12:28 PM | #19 |
Will the stock plugs work with the lipo? Ir should I just convert?
03-28-2012, 12:38 PM | #20 |
Stock plugs will work but its best to cover to deans better conection with deans. The stock plugs get to hot for me
Mrc lipo upgrade suggestions - Similar Threads | ||||
3c Lipo suggestions for Wraith please | NCT_Guy | Axial Wraith | 13 | 03-16-2012 11:12 PM |
Wraith Newb... Upgrade Suggestions. | quadracer905 | Axial Wraith | 6 | 12-27-2011 06:41 AM |
Lipo suggestions | Lil red Nissan 720 | Electronics | 0 | 11-02-2011 10:01 PM |
suggestions for wraith radio upgrade | Wavekatcher | Electronics | 3 | 09-24-2011 09:34 PM |
Lipo upgrade | TSK | Electronics | 21 | 06-27-2009 10:28 PM |
