03-11-2012, 04:50 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: SW Iowa
| comp ride height?
Building my first mrc for comps, building one from several so I'm mixing and matching parts. Decided to go with an aluminum top, a little top heavy, so I wanted to keep it as low cog as possible. Belly is at 2.25", compressed, 1.5", lifting the front tire I can get 3.5" under the tire before it raises the rear. Tires have smaller foams, so a little of the compression is in the tires. How is this sounding? |
03-11-2012, 07:20 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: comp ride height?
I'd say you look like a candidate for a full-droop suspension. Many tubers use them due to the high body cg. And if anyone dis's you for the suspension, remind him the current 1.9 national champion won with a full-droop mini.
03-11-2012, 07:40 PM | #3 |
The shocks that are on it now are the smaller losi late model shocks: losb1289, 2 1/8" eye to eye, just about 1 1/2" compressed, should I go with these, or go with the standard mrc shocks?
10-12-2012, 07:18 PM | #4 |
Newbie Join Date: Oct 2012 Location: carmichaels
the smaller late model shocks are okay because they are shorter you wont get tons of articulation but to much is bad personaly ur ride height would be a little tall for me but its something that you have to experament with and find what is going to work for you
comp ride height? - Similar Threads | ||||
ride height | thor_woody | Axial XR10 | 31 | 12-20-2011 01:00 AM |
ride height? | jasons36 | Axial SCX-10 | 0 | 04-23-2010 03:34 PM |
Ride Height | kid rock | EnRoute Berg | 3 | 04-16-2009 12:27 PM |
Ride height versus max height | Manson | Axial AX-10 Scorpion | 9 | 10-03-2008 01:26 PM |
Ride Height?? | sniders1975 | Axial AX-10 Scorpion | 10 | 08-27-2008 01:57 PM |
