06-24-2012, 10:08 PM | #1 |
Quarry Creeper Join Date: May 2009 Location: pacific NW
| Tire bind problem...
I noticed today the my front right tire is binding while it rotates under power. The other 3 spin fine. It has a pause while it spins. Does that sound like a bad bearing? Sent from my PC36100 using Tapatalk 2 |
06-24-2012, 10:50 PM | #2 |
After looking at it some more, it appears the the other front tire also binds a bit. Not near as bad as the right though. Could be the right tire binding is causing the left to appear to bind. This was a used roller when I got it. I don't remember if it was doing this when I first got it running. But I did just do the over drive mod. Maybe it needs to be shimmed. I'm gonna go to the store tomorrow, get bearings and shims and see if that helps. Sent from my PC36100 using Tapatalk 2 |
06-26-2012, 11:25 AM | #3 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Tire bind problem...
sounds like it just need shimmed.
Tire bind problem... - Similar Threads | ||||
Tire problem | The-Blacksheep | Axial SCX-10 | 6 | 02-20-2012 07:23 PM |
Bind and control problem | MNorby | Electronics | 5 | 10-09-2010 12:30 AM |
Tire Problem | bschimmel | Axial AX-10 Scorpion | 1 | 06-18-2010 10:09 PM |
Tire problem | Rbs1987 | Losi Mini-Rock Crawler | 3 | 03-15-2009 05:43 PM |
