12-10-2014, 08:07 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Port Charlotte, FL
| Where to get a servo and battery
What servo and battery are ya'll using i can't seem to find any on ebay i need a steering servo with servo horn but alls i find is without the horn any help would be appreciated
12-10-2014, 08:17 PM | #2 |
| Re: Where to get a servo and battery
Would this work at all?? Miscellaneous All Analog Metal Gear Servo 1.5kg /10sec CYS CYS-S0009A |
12-10-2014, 08:38 PM | #3 |
Get a normal 1/10 scale servo. You be Much happier! And too much torque doesn't exist.. Lol.. I run a 7950 on my mrc.. A Hitec 5645 would be a good buy, if ur not competitive crawling |
12-10-2014, 09:11 PM | #4 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Where to get a servo and battery Yup. I have a 645 on my MRC and it isn't bad. But I need way more torque for the type of stuff I do. Another 7955 would be my next option probably.
12-10-2014, 09:19 PM | #5 |
| Re: Where to get a servo and battery |
12-10-2014, 09:20 PM | #6 |
I have a 645 i just mounted up and it won't stop does a full 360 cause it used to be a winch is there a way to make it work or no?
12-10-2014, 10:32 PM | #7 |
12-11-2014, 04:46 AM | #8 | ||
| Re: Where to get a servo and battery Quote:
Nuff said... | ||
12-11-2014, 07:42 AM | #9 |
I use servo city for servos. Sometimes Ebay. I would recommend Hitec, it is a personal choice. I have tried other servos out there with little success, and check out Value Hobby for batteries. https://www.servocity.com/html/hitec_servos.html http://www.valuehobby.com/power-syst...-lipo.html?p=2 |
12-11-2014, 03:21 PM | #10 | |
It would be going in my MRC, so I'm not looking to spend a whole lot on a servo right now. Might get a solar D772 to get me by until I can get a real servo. | |
12-11-2014, 09:41 PM | #11 |
HS-55 any good?
12-11-2014, 10:22 PM | #12 |
| Re: Where to get a servo and battery Ooh no. The HS-55 is way to small and really not even close to having the torque required for a crawler. I'd get one of these as a starter servo to see if you need more torque for what you're doing. If you do need more torque then you can get something stronger. HS-5585MH Economical, High Voltage, High Torque, Coreless, Metal Gear Digital Sport Servo | HITEC RCD USA Or HS-5685MH High Voltage, High Torque, Metal Gear Digital Sport Servo | HITEC RCD USA Or you can get a Solar D772. |
12-12-2014, 02:45 AM | #13 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
To make the servo into a winch you needed to re-install the stop and the potentiometer inside. It is a lot of work and not worth it vs the cost of a new servo. I use a 7950 on my mini and it works nicely! Big thing you have to keep in mind is the ESC can't put out very much current so a BEC is necessary. I use a castle one since it is teeny tiny and very powerful Castle Creations | CC BEC and CC BEC Pro To make a standard servo mount work you need to first find a mount or fab one up (or have someone cut it out for you.) Then you will need some decent servo mounts and then your set A big servo makes a HUGE difference... Originally I had some pitiful servo on there and Troy kept nagging me to put a bigger one on... bla bla bla later I finally listened and never looked back |
Where to get a servo and battery - Similar Threads | ||||
What Battery For Use With Front Servo/Battery Plate? | Shanty | Axial AX-10 Scorpion | 23 | 08-13-2009 03:05 PM |
Noisy servo?? 7v battery on 6v servo? | Benjitis | Electronics | 3 | 07-15-2009 12:01 AM |
battery/servo | ped453 | Losi Mini-Rock Crawler | 3 | 06-18-2009 03:26 PM |
battery for servo only | shierkahn | Electronics | 4 | 02-24-2009 10:53 PM |
two questions regarding battery and servo | srfrkyle1234 | Electronics | 1 | 02-01-2007 05:26 PM |
