Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: dropped and stretched...driveshaft ideas?
Old 12-19-2014, 09:20 AM   #1
Default dropped and stretched...driveshaft ideas?
Laying here in bed, with the flu. Using my kindle, and couldn't get the search function to work. So, sorry if this question has been asked a hundred times...
I recently stretched, and dropped my MRC. Going for a scale build. Custom fab job, all the way. Longer suspension links made out of thick "tomato-cage" wire... Custom aluminum plates to extend the y-arms. Sounds shady, but it's solid.
The wheelbase is now 10". Hopefully I can use a cc01 land cruiser body. Possibly a newbright lr3...or something else.
My question is, are there any drive shafts available for this longer wheelbase? Possibly off another crawler? Or from a hopup parts manufacturer? My drive shafts of course no longer connect...I've got a tentative custom fab design in mind, but would consider a simple pay-n-play if one is available.
Any good links to other member's MRCs that are dropped and stretched?
Thanks for your help, guys...
ladoga2015 is offline   Reply With Quote
Old 12-19-2014, 09:33 AM   #2
Scale Detail Engineering
Default Re: dropped and stretched...driveshaft ideas?
Traxxas mini shafts work great and are really strong:
Buy 1 of these: Traxxas #1951
Buy 2 of these: Traxxas #1539R
Used them here for 9.5" and had to cut them down
Dinky MRC build
johnnyh66 is offline   Reply With Quote
Old 12-19-2014, 09:43 AM   #3
Awesome, thanks....I'll check those out.
Old 12-19-2014, 09:59 AM   #4
Thumbs up Re: dropped and stretched...driveshaft ideas?
Just checked your thread....badass.
Old 12-19-2014, 11:16 AM   #5
MIPS with 4mm Allen wrench welded to the male end. Would be the modded way to go.
winnerone23 is offline   Reply With Quote
Old 12-19-2014, 12:58 PM   #6
What about these? :
PROPELLER SHAFT (4mm to 4mm) - Scale Designs International
JENS is offline   Reply With Quote
dropped and stretched...driveshaft ideas? - Similar Threads
Need some ideas for a driveshaft camobob General Crawlers 2 04-02-2011 09:32 AM
Driveshaft extention Ideas?? crawler_king Losi Mini-Rock Crawler 10 02-15-2009 06:23 AM
Driveshaft ideas for stealth tranny? Rockinrockcrawler Tamiya TLT Crawlers 20 11-03-2005 06:16 PM
