12-23-2014, 06:52 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Novak 380 issue
I posted this in the electronics forum but no one replied. So, I'll try here. I have a novak 380 in my MRC with a Losi Xcelorin 1/18 crawler ESC. I have the wires hooked up just fine and my battery has power. I have forward, but no reverse or brakes. I've tried different batteries and re-calibrated the esc and that still didn't help. I have no idea what's wrong with it and I can't connect it to the computer with the little adapter. I need help. Also, does it matter if I use the castle link cord with the losi esc plug adapter?
12-24-2014, 04:21 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: Novak 380 issue
I do not have an Xcelorin system, but it seems like you are in race mode. You need to look at the programming of the ESC
12-24-2014, 04:53 AM | #3 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Novak 380 issue
If this adapter works I want one. I have an old Xcelorin that would be nice to program without the beeping and button pushing.
12-24-2014, 07:31 AM | #4 |
Pebble Pounder Join Date: May 2013 Location: lemont
| Re: Novak 380 issue
I own the same esc except I have the losi motor...in the manual all of the preset profiles have reverse. Therr is no race type modes because it was made specifically for the mrc...so my only thought is that someone either programed it manually with the card/computer to not have reverse or the esc is the issue... u got to either get a hold of a quick program card or get that computer set up running. ... my link setup came with a disk also but I do t know if u can just get the info from the internet...
12-24-2014, 03:10 PM | #5 | |
| Re: Novak 380 issue Quote:
12-25-2014, 05:43 PM | #6 |
RCC Addict Join Date: Jan 2009 Location: Bend
| Re: Novak 380 issue
Why are you trying to run a sensored Novak motor with a sensorless Losi ESC? Novak specifically stated that their motors ARE NOT to be used with sensorless ESCs. The fact that it still runs is amazing in it's own. My Novak lost one wire in the sensor lead bundle and burnt up two sets of windings in the motor because of it.
12-25-2014, 05:53 PM | #7 | |
12-25-2014, 06:05 PM | #8 | |
It's news to me. Never heard of such a thing. Not arguing, just never seen one. I just know that trying to run these motors on a sensorless ESC does nothing but cause more problems. Even other sensored ESCs I tried threw fits with the Novak motor. Very coggy and jumpy. For whatever reason, it was one of the most particular motors I ever ran. Shortly after the sensor lead broke it got canned in favor of a Micro Sidewinder and Extreme 380 brushed motor. Had I known I'd like that combo so well I would have probably never bothered with brushless in a comp style rig in the first place. The brushed setup as a whole is much more compact, lighter, simpler, smoother (though the Novak is pretty damned smooth for a BL setup...) and still has plenty of power. Just a thought, have you tried turning all your EPAs and trims back to zero before re-calibrating? Occasionally my kids will mess with my TX knobs, and next thing I know I have no reverse or braking... | |
12-25-2014, 07:38 PM | #9 |
| Re: Novak 380 issue
I'm going to to go try that and see what happens. Also, I'm probably going to order a Cobalt 380 too so I have a reliable set up too.
12-25-2014, 08:09 PM | #10 |
| Re: Novak 380 issue
Well, it wasn't the EPA's. I thought to myself, maybe I should try changing the profile. Went to profile #1 and now I have reverse. Thanks for the suggestions guys. I can't believe it was something as simple as changing the profile on the ESC and that it never crossed my mind. |
12-26-2014, 07:30 PM | #11 |
Quarry Creeper Join Date: Dec 2012 Location: Hells basement
| Re: Novak 380 issue
The three 80 is a good motor I know your not suppose to run it without a sensored ESC but mine had the sensor go bad an novak does not just service that one part on the three 80 you have to trade in a new motor. Been running mine for a couple years without a sensor'ed esc I really need to pull the bad sensor board out of the motor an plug its opening to seal the motor up.
Novak 380 issue - Similar Threads | ||||
Novak 380 | OTHGbronco82 | Electronics | 10 | 10-21-2012 06:36 AM |
Novak Mongoose 380 Pinion shaft Size?? | skullking | Electronics | 9 | 07-12-2011 06:19 PM |
