Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Losi mrc wheel lift.
Old 08-22-2016, 11:14 PM   #1
Default Losi mrc wheel lift.
Hi everyone, I recently started mousing my losi mrc rtr edition. So far threaded shocks, hr front knuckles, hr front c hubs, integy front steering links, axial 1.9 beadlocks with axial wheel weights mount with super swampers. It ran fine but after I decided to install a rear servo and the original steering setup in the rear I'm staying to get front and rear wheel lift when cornering hard. Any ideas why it's doing that when in 4ws?
Ausomecrawl is offline   Reply With Quote
Old 08-23-2016, 11:48 PM   #2
Default Re: Losi mrc wheel lift.
Anyone? After a little digging sounds like it might be related to torque steer. Does anyone know a fix? I'm not sure I'd mirroring the trans will help since I have the same issue going backwards (4ws)
Old 08-25-2016, 12:30 AM   #3
I decided to get my slicKroc back together so I could test. Discovered that my problem transfered to the slickrock when I swapped overy my axial wheels with axial weights. So now I know my problem is with torque twist( right front wheel lifts when turning right and accelerating. Left rear wheel also lifts) and the weighted wheels(problem moves to whatever crawler I move the weighted wheels to). I'd like to keep my weighted wheels as the crawler doesn't flip over as easy as without weights. Any advise?
Old 08-31-2016, 01:31 PM   #4
Great place to start would be
The beginers guide to the MRC.
Flip the trans it works
hillbillyrc is offline   Reply With Quote
Old 09-03-2016, 12:59 AM   #5
Thanks. It's worth a shot. I'll try if.
Losi mrc wheel lift. - Similar Threads
losi mrc wheel option hydro0309 Losi Mini-Rock Crawler 5 12-15-2012 01:31 AM
