Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: out on a limb underdrive
Old 11-01-2016, 07:45 PM   #1
Lightbulb out on a limb underdrive
I've been researching the underdrive mod. So far I have found mixed results in old posts between 2010 to 2014. Everything at has worked has been time consuming to make, fit and shim but not saying it wouldn't be worth it in the end. In one post seen a few guys say they have looked around for something more drop in.
I'm going out on a limb here and has anyone considered this
Differential Pinion Gear. Fits all NITRO: Lightning, Tornado, Tsunmai, and Volcano models
In rigs it works with is listed the everest 16.
Is it a big limb I'm inching out on or have it stumbled across something?
hillbillyrc is offline   Reply With Quote
Old 11-02-2016, 01:32 AM   #2
Default Re: out on a limb underdrive
May work, Id be worried about how much of a shoulder it seems to have on it.
clod booster is offline   Reply With Quote
Old 11-02-2016, 05:18 AM   #3
That was my only concern too
Old 11-02-2016, 07:58 AM   #4
I had the same thought and ordered an HSP pinion (same part and part number) last week. Way easier to remove that extra material from the back than mess with the teeth on a lathe. I'll post back if it works.
TownsendTdi is offline   Reply With Quote
Old 11-02-2016, 11:31 PM   #5
DravTech
Dravpnir's Avatar
Isn't the stock pinion gear also a 13T?
Dravpnir is offline   Reply With Quote
Old 11-03-2016, 01:02 AM   #6
Stock is 14 teeth, the revo pinion for overdriving the front is 16 teeth.
Old 11-03-2016, 07:25 AM   #7
Originally Posted by rock hard View Post
The stock pinions are 14t
The overdrive mod using a traxxas mini revo pinion is a 15t
With 15 up front and 13t in the rear was good.
Your just a tooth off. The place I found that quote rock hard was making a 12t but a 13t will work. Just like the overdrive gear is a 15t just going up a tooth made alot of difference. Going down a tooth from stock should be just as befitting.
Old 11-09-2016, 07:58 PM   #8
That pinion fits the 1/10 Everest not the 1/16. It will not work.
f150monster is offline   Reply With Quote
Old 11-10-2016, 06:06 AM   #9
Nice try, but I did my research before I posted and looked at all the facts.
Old 11-11-2016, 10:33 PM   #10
Well I ordered one today so I can test out my idea and picked up an overdrive gear for good measure
Old 11-12-2016, 05:13 PM   #11
Talking Re: out on a limb underdrive
Ok, I didn't say that you didn't look at the item description but it still won't fit. Enjoy
Old 11-12-2016, 06:27 PM   #12
Why won't it work since you seem pretty confident it won't?
How about you back up your statement with some info just seems like your trolling.
Old 11-12-2016, 06:56 PM   #13
Because I have modded the crap out of the exact axles that you are working with and have one of those exact pinions hanging above my bench because I believed the description. I just thought I'd let you know so you didn't waste your time and money. No worries though, I'm obviously just here trolling.
Old 11-12-2016, 07:21 PM   #14
I don't have a everest 16, but another clone axle. And not a waste of money if it don't work cause my son has a everest 10 so I can use it there.
Also why didn't you just say you bought one and tried it instead of it won't work would have been much easier.
Just FYI
Old 11-13-2016, 07:22 AM   #15
Right on, at least you have something else to put it in.
Old 11-15-2016, 08:58 AM   #16
The HSP one I ordered finally arrived, $3 shipped- you get what you pay for lol
This one is way too large
Old 11-15-2016, 03:13 PM   #17
My son has an everest 10 so money isn't wasted for me. It was a big IF anyways.
out on a limb underdrive - Similar Threads
Scale Limb Risers pl626 General Scale Talk 3 11-03-2021 03:31 PM
TH Over- or Underdrive tomster Vaterra Twin Hammers 1 07-17-2014 11:37 AM
limb risers/bush cables noogles Scale Accessories 11 03-14-2011 08:56 AM
Ok im going out on a limb here SMUDGEBUG Chit Chat 6 02-09-2010 08:47 PM
