Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Custom length driveshafts?
Old 09-15-2017, 02:27 PM   #1
Default Custom length driveshafts?
I searched the stickies threads and was unable to find any driveshafts other than stock length. I also tried doing a search however my phone wasn't getting the drop down box to come up. I have a build I'm working on and these are the perfect width axles but I need to take wheelbase from approximately the 8.5 it is standard to approximately 10.
.5 to fit the body I want to place on it. Does anyone know of anyone who makes custom length driveshafts to fit the 4mm outputs? The other possibility is if there is a way to fit 5mm driveshafts and use a 1/10 trans and a 540 motor
corwin is offline   Reply With Quote
Old 09-15-2017, 05:58 PM   #2
Default Re: Custom length driveshafts?
Sdi makes a set you can cut to whatever length you need.
Perkul8r is offline   Reply With Quote
Old 09-15-2017, 07:56 PM   #3
Thank you sir I forgot all about sdi. I appreciate the help
Old 09-16-2017, 11:34 AM   #4
I had to think about who it was that made these for a bit. I wanna say they are the only place I have seen that make ones for the small outputs of the Mini Crawler. And they aren't bad priced either.
Custom length driveshafts? - Similar Threads
Length of mip c drive driveshafts dwblue00 Axial SCX-10 1 08-14-2016 07:51 PM
How to build custom length driveshafts mtm Losi Micro-Rock Crawler 3 04-27-2015 06:45 AM
Custom length links bigj00 General Scale Talk 1 01-18-2010 03:02 PM
help! driveshafts length! ah_5500 General Crawlers 6 03-31-2009 11:45 PM
Does anyone have the length of the Stampede driveshafts fully extended? Flatty General Crawlers 3 03-20-2009 11:24 PM
