Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Axle slop
Old 11-08-2017, 02:02 PM   #1
Bpw
Default Axle slop
Ok So I'm relatively new to the crawler scene. I've got a few but my losi pro 1/18 seems to have a lot of slop in the axles, left to right they have a decent amount of sway I guess you'd call it. Trying to fix it has got me stumped, I pretty sure it's not supposed to be like this?
Site won't let me post a pic, which would be super helpful if it would...
Bpw is offline   Reply With Quote
Old 11-08-2017, 09:11 PM   #2
Default Re: Axle slop
Move the upper links outboard the chassis plates. This will require outboarding the lower ends of the shocks to get the shocks to clear the links. These cars need all the triangulation they can get though, which what you achieve by moving the links.
Also, make sure all the link hardware is tight. A loose rod end ball at the chassis end can quickly add up to a ton of diagonal play between the chassis and axles.
Sent from my SM-S975L using Tapatalk
89redranger is offline   Reply With Quote
Old 11-10-2017, 11:15 AM   #3
Bpw
The link hardware is tight, wish I could show you what I'm taking about...
I'll try outboardingthe links good idea I hadn't thought of, thanks!
Old 11-10-2017, 02:34 PM   #4
Bpw
Man, thanks a lot redranger worked perfect never thought of it.
Future searchers for axle slop this worked wonders in my losi pro. Just flip the hardware on the upper links and move the lower mount point out on the shocks. The second part requires longer screws or a nut.
Thanks again man, whole new truck!
Old 11-10-2017, 03:50 PM   #5
No problem man. Done this a time or two...
I usually use longer M2 screws and an extra rod end pivot ball as a spacer. Those little tiny tabs WILL NOT support the shock hanging off them alone.
Old 11-10-2017, 03:54 PM   #6
BTW, you'll still find slop where the lower links fit the pockets in the skid. There is no way I know of to tighten that up short of a better fitting piece of music wire or similar. Moving the uppers outboard at the chassis fixes 90% of the slop though. The rest should go fairly unnoticed now.
Old 11-10-2017, 06:23 PM   #7
Bpw
Boom, more good advice. I definitely had an mounted to the one tab. Definitely don't wanna break it. Went to the hardware store got some longer screws and put some pivot balls in there out of a mini T had to double it up at each corner but it's all buttoned up and so much better! Thanks again man, sharing knowledge... good stuff. Gonna go hit the rocks!
-Brian
Axle slop - Similar Threads
axle slop?? tweak6 RC4WD Bully 11 11-15-2013 04:50 PM
slop in axle TWOPLANKER G-Made Crawlers 0 03-22-2013 11:02 PM
Slop in Axle BennyTRD Axial SCX-10 3 05-06-2012 10:27 AM
Axle Slop or something else? kyleman7 Axial SCX-10 10 03-30-2012 06:27 AM
Axle Slop apuinator Losi Mini-Rock Crawler 4 06-02-2009 12:38 PM
