Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Losi Rock Rey
Thread: does the RR kit have open diffs? (and newb questions about kit)
Old 09-09-2018, 10:07 AM   #1
~THE SCALE SHOP~
Question does the RR kit have open diffs? (and newb questions about kit)
im looking at picking up the kit version. i want to do a track focused build.
so i actually want all 3 diffs to be open/not locked, like a SCT. for best handling/cornering.
losi lists this:
"Drivetrain:4wd (locked rear, gear diff front and rear" (do they mean center?)
are they saying the front and center are gear diffs, and the rear is locked? could a gear diff be added to the rear?
also what other areas need to be addressed? i plan to run a 2S, 550 4 pole 4300kv setup. ie SCT race setup.
weaknesses?
STANG KILLA SS is offline   Reply With Quote
Old 09-09-2018, 12:55 PM   #2
Default Re: does the RR kit have open diffs? (and newb questions about kit)
There's no center diff you can unlock on a bomber. Front and rear diffs come locked from the factory but the yeti front diff parts will drop right in.
Almighty Malach is offline   Reply With Quote
Old 09-09-2018, 01:42 PM   #3
~THE SCALE SHOP~
Old 09-10-2018, 03:01 AM   #4
The answer to the question is NO , not without some serious modding ,...
a chap on fb group did unlock the rear by using a vanquish axle ,...
but you could pop into your local engineering shop and get them to turn out some rear axles for you , I can’t seeing being more expensive than a vanquish axle setup !
The square ended axle shaft just need to removed and replaced with the front output design which has a cross pin that engages with the king gear inside the diff , not that difficult at all really if you know what your doing !
Creeper bob (a vendor on here ) might be able to help you he machines titanium axles for lots of different rigs
willyg1981 is offline   Reply With Quote
does the RR kit have open diffs? (and newb questions about kit) - Similar Threads
New Gmade Sawback 4LS Kit open for Pre-Order RPP Hobby RPP Hobby 0 02-23-2016 12:01 PM
Questions about original AX10 KIT (first gen.) and latest KIT GWEEDZ Axial AX-10 Scorpion 10 02-18-2012 07:30 AM
gears for open diffs missing in ax10 kit? izeman Axial AX-10 Scorpion 6 01-20-2010 02:28 PM
Best complete kit *newb* kodyharrell Newbie General 10 01-18-2010 01:11 AM
