Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Losi Rock Rey
Thread: Must do mods for durability / common breakage?
Old 07-22-2019, 06:55 AM   #1
Default Must do mods for durability / common breakage?
Hi all,
Searching around on a few forums, I didn't find a thread like this for the Rock Rey, but if one exists, please let me know and I'll request this to be deleted...
Wondering if we can get a list of "budget friendly do-firsts" for modifications. What I mean by this is, truly common breakage vs nice to have. (I know we'd all love a fully aluminum truck...
So far in my research, I've found:
  • Losi 23T Aluminum Servo Horn (if using stock servo) - TLR1555
  • Larger screws for each diff ring gear - 2.5 x 10mm - Traxxas #2523 (12 needed), will need cobalt drill bit - Avoids sheering off screw heads
  • SSD Rock Rey Third Member - #SSD00177 - Aluminum housing prevents case flex and protects ring & pinion
-Dale
FastGT94 is offline   Reply With Quote
Old 07-22-2019, 08:57 AM   #2
Default Re: Must do mods for durability / common breakage?
If you are planning on running 3S, well, good luck. I am not kidding when I say my truck has broken every time I drive it.
I would say Exotek diff cups and probably the metal rear axle third member/front diff housing are a must. Ive blown out my stock rear diff cup and had sheared off 3 of the 4 screws on my front when I went to install a locker.
One of the pinion bearings in my rear axle exploded the other day so the pinion started walking around inside the housing and mess a bunch of stuff up. Bought an SSD 3rd member.
mass-hole is offline   Reply With Quote
Old 07-27-2019, 08:07 AM   #3
I have the kit version the only problem I ever had was the servo horn came off. Only running a 2S.
1FSTLS1 is offline   Reply With Quote
Must do mods for durability / common breakage? - Similar Threads
Axial Dig Durability vs Vanquish Durability DarkBlack Newbie General 10 02-27-2019 10:50 AM
Few mods, parts breakage...need help. optikalillushun HPI Wheely King 3 07-02-2012 10:03 PM
ax10 axle breakage or no breakage Oregon crawler Axial AX-10 Scorpion 12 08-15-2011 03:20 PM
common mods to the high lift iwantoffroad 1.9 Scale Rigs 2 10-06-2007 03:16 AM
Common breakage BrockGrimes Tamiya Clod Buster 6 03-10-2006 02:37 PM
