12-22-2017, 02:13 AM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: Australia
| Stronger CVD availability?
So ive heard of a few breakages now with the cvd's, has anyone made a better stronger setup?
12-22-2017, 09:42 AM | #2 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: Stronger CVD availability?
I don't think so, their stock ones are expensive too, for a stock part.
12-22-2017, 11:03 AM | #3 |
The stock setup looks flimsy to me...there's no barrel inside, the axle rotates on a pin only. The upgrade CVD available is a more traditional cvd setup where the pin is captured and should be much stronger. Plan to run mine until it fails, then upgrade. |
12-22-2017, 06:45 PM | #4 |
Thanks fellas. Might look into what can also be made to fit |
12-25-2017, 01:43 PM | #5 |
Rock Stacker Join Date: Oct 2014 Location: New zealand
I reckon the stock setup is stronger than normal cvds, theres way more meat due to being no barrel. However i believe they are not as smooth, with more slop. Mst cfx Axial wraith Axial yeti 8x venom creeper |
12-25-2017, 01:47 PM | #6 |
I joined the Band! Join Date: Mar 2009 Location: Right Here
I’ve broken a couple, but only because I was steering endpoints were off and the pins were coming out and binding. Since I’ve fixed the endpoints, no issues. Sent from my iPhone using Tapatalk |
Stronger CVD availability? - Similar Threads | ||||
Looking for 58mm - 60mm CVD/CVD Swing Shaft | Michi | Non Crawler RC's | 0 | 02-23-2017 11:17 AM |
stronger front axle shafts with cvd? | vxlblitz | Axial SCX-10 | 9 | 06-28-2012 03:49 PM |
Which CVD set is stronger MIP or AXIAL?? | Desert Rc | Axial AX-10 Scorpion | 43 | 04-24-2010 10:48 AM |
