01-06-2018, 03:54 PM | #1 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Broken Portals
So I finally got my scale Unimog CFX-W mostly done. It is running a 23T pinion, 3500 KV HH motor and it has a bunch of extra weight. I’ve made a steel subframe and it runs a roll cage and hardbody body. I also run very heave 2.2 wheels with small 2.2 tires. I also run bearings instead of bushings. My portal just blew up on its maiden battery after full assemble. It was climbing over a small incline. There was a mild hop and boom- gears blew up. I couldn’t find any upgraded parts only replacements. Have others had this problem? I hate to think that the portal design has a flaw after I spent 3 months building the platform. Thanks! |
01-06-2018, 05:07 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Broken Portals
As far as I know MST is lack of option parts, I would humble to suggest you to lower your truck’s weight and maybe lower kv motor would also help. We all know we like speed and fast acceleration and all these could broke a scale crawler parts easily. Cheers P/s, lower your gear ratio also would help since you’re using 2.2 Last edited by Teng; 01-06-2018 at 05:09 PM. |
01-06-2018, 06:29 PM | #3 | |
| Re: Broken Portals (and how to host) Quote:
Crap, this whole build was based on portal axles. P.S. how are folks hosting pics these days (now that photo bucket is dead) so I can show the carnage and the rig? | |
01-07-2018, 11:45 AM | #4 | |
| Re: Broken Portals Quote:
Here is a pic I also threw up in another thread. Pics of the rig in its current stage of finish below. Sent from my iPhone using Tapatalk | |
01-07-2018, 04:35 PM | #5 |
| Re: Broken Portals wow, looks like a real truck. Amazing. As we earlier discuss it seems the weight really contributed to broken your parts. Need diet already Sent from my iPad using Tapatalk |
01-07-2018, 04:51 PM | #6 | |
MODERATOR Join Date: Oct 2010 Location: RC Land
It appears there's not much there for weight. If the portals can't handle that little bit, not sure what they could. I'd say it was just a poorly cast part, but who knows. It's just part of the hobby, break em and fix em over and over. Just stinks when it's minutes into a maiden voyage. Like looking MOG | |
01-07-2018, 04:55 PM | #7 |
| Re: Broken Portals
Ya, you are correct too. This truck need heavy duty CNC gear set. But unfortunately the MST is lack of after market support. Sent from my iPad using Tapatalk |
01-07-2018, 08:29 PM | #8 | |
I will see how a replacement set of gears does but it will take a month for them to even show up. I honestly don’t know that anyone couldn’t have a problem if they had a similar set of gears. I’m very disappointed. | |
01-08-2018, 07:42 AM | #9 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: Broken Portals
My rig weighed in at 5.1#s, gears never lasted more than 15 minutes. FAWK MST AND ASIATEES:flipo ff: |
01-08-2018, 09:38 AM | #10 |
| Re: Broken Portals
You added a lot of weight over stock. It would be interesting to see what your truck weighs, but 1/2" square tubing and steel rod isn't light. The gears simply aren't meant to handle that. The didn't hold up as well as I would have liked, but maybe you got a bad batch. I would honestly contact MST. Send them your photos and let them know the gears are weak. Hopefully they replace them and hopefully things like this can convince them to give us hardened gears as an upgrade. MST usually makes high quality stuff. |
01-08-2018, 04:39 PM | #11 |
| Re: Broken Portals
It is exactly what I wanna to say. I found a lot of stock RC crawler favour in 2s Lipo pack. Any stock crawler on 3s Lipo will be shorten their life in gears, CVD, driveShaft etc... just as Jato mentioned as above. I hope you find out the solution soon. Thank you Sent from my iPad using Tapatalk |
Broken Portals - Similar Threads | ||||
portals | Werock | Axial Wraith | 6 | 11-20-2016 12:48 PM |
What do these portals go to? | Hoosierdady | General Crawlers | 4 | 12-02-2013 08:12 AM |
Anyone seen these portals before? | infanterene | Tamiya CR-01 | 18 | 06-23-2009 02:25 PM |
portals? | 0778drz110 | Newbie General | 0 | 11-03-2008 03:31 PM |
portals!! | Big Mike | General Crawlers | 1 | 01-30-2007 11:45 AM |
