Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CFX
Thread: CFX-W Axle Shaft issue
Old 12-27-2018, 08:13 AM   #1
Default CFX-W Axle Shaft issue
I was wondering if anyone has had issues with the internal axle shaft on the CFX-W? I have broken 3 of them under what I call normal use.
I have tried to contact MST on facebook and they do not respond. I also contacted Asiatees and the cannot help except provide the part number to replace the part.
So far I have spent almost $100.00.
Thanks!
RCCasper is offline   Reply With Quote
Old 12-27-2018, 08:19 AM   #2
Default Re: CFX-W Axle Shaft issue
No issues on my end. What kind of power and how heavy is your truck?
Pictures of axles?
soze is offline   Reply With Quote
Old 12-27-2018, 08:39 AM   #3
Their axles are terrible. I keep blowing the portal gears. I am running brushless. It’s an inferior design. I have a beautiful unimog that I can’t run.
This sort of failure is inexcusable.
MeanTT is offline   Reply With Quote
Old 12-27-2018, 08:41 AM   #4
I'm running 35T Brushed and fairly light. That's probably why I haven't had any issues.
Old 12-27-2018, 02:07 PM   #5
I’m running 27t on a lexan body and I haven’t any problem.
Andersen72 is offline   Reply With Quote
Old 12-28-2018, 07:59 AM   #6
I am running a 35t motor , the truck does have a weighted wheels up front also the battery is moved forward. If I had to guess, it would be about an 8 lbs rig.
Thanks
Old 01-29-2019, 10:23 AM   #7
I've just had mine about to build with front weighted heavily to run with 30t torquemaster exp driven by HH brxl! Any heads up or do's n don'ts with this rig will be highly appreciated.
Sent from my SM-N950F using Tapatalk
YANGON-RC is offline   Reply With Quote
Old 01-30-2019, 08:27 AM   #8
I have had my Cfx-w with lexan CJ body for two years now, on any terrain from hiking in the woods to rockcrawling on rocky seashore, and it's been perfect! (knocking on wood...)
To my experience this is a great little chassis that works well in light vehicles.
Heavy rigs and lots of power don't match the tiny gears, but they are perfect under a lightweight body with just enough power to be nimble to drive
My CJ, just to give some numbers, weights a mere 5,5lbs, with Rc4wd steel snowflakes without any weight and TSL's, Mamba MicroX driving a small 2836 outrunner (Aerodrive SK3) on 3s 2200, which provides abt.400W of power.
Before that I've used 600 sized brushed 27t on BRXL, same 3s lipo, and weight was just shy of 6,5lbs.
I love this nimble rig with portals, but would not recommend it for anything heavier than this.
Wants to build a heavy Unimog style rig 8plus lbs? go Trx4 route.
Cfx-w is for lightweight jeeps or bugs, not for trucks
rockspider is offline   Reply With Quote
Old 02-02-2019, 12:20 PM   #9
I do agree a heavy rig may cause the issue with this. I have the battery up front along with weighted wheels. It could be to heavy!
Old 09-24-2019, 01:52 PM   #10
Proper shimming is key
MAGNUMB is offline   Reply With Quote
Old 09-25-2019, 07:30 AM   #11
Well, not sure about shimming, they have come out with a hardened replacement since there were some many issues and complaints.
CFX-W Axle Shaft issue - Similar Threads
CFX-W MPA axle panhard fr8cture Max Speed Technology CFX 12 01-04-2018 09:15 AM
Rear axle short shaft issue? Katan Axial Wraith 216 04-24-2017 06:46 AM
HR spool/axle shaft issue Devil Inc Axial Wraith 0 05-08-2013 09:50 AM
best way to join a rwvo drive shaft to the output shaft on the axle TRAV Kyosho Crawlers 12 01-29-2012 07:37 PM
