Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Max Speed Technology CMX
Thread: MST CMX Bronco
Old 04-26-2017, 09:11 AM   #1
I joined the Band!
Default MST CMX Bronco
My kids love driving my tiny trucks so I got each of my twins an MST CMX, this Bronco version and the other will use a Land Rover Defender hardbody.
I'm really bad at painting so I was happy with how this body came out, only a couple bleed through sections and one glaring omission, I didn't paint the fender flares black. The sticker sheet had decals for the fenders, but I later realized they didn't cover the whole fender...ooops...Not sure what to do, in open to suggestions
I'm not gonna post a play by play of the chassis assembly, I will say the only complaint I have about the MST kit is lack of ball bearings, but I've read some compelling cases for bushings in these low speed applications. I installed fast Eddie bearings on this one, maybe I'll do bushings on the other for comparison.
I'm using a power HD 20kg servo, a 45t RC4WD motor and a New Rain 160A ESC.
I have the same servo and and the next size bigger ESC on my HG P402 and I have had zero problems.
spaceman5280 is offline   Reply With Quote
Old 04-26-2017, 09:13 AM   #2
I joined the Band!
Default Re: MST CMX Bronco
Black ultra fine sharpie for the door cracks
Silver sharpie for the window trim
Old 04-26-2017, 09:25 PM   #3
I joined the Band!
Stock wheels
Wheel option #2
The rear wheel looks centered, but the front axle needs to go forward, I'll make some adjustments and then try more wheel/tire options.
Old 04-26-2017, 11:15 PM   #4
I like option #2, but would think it might look better in white.
hillbillyrc is offline   Reply With Quote
Old 04-27-2017, 06:13 AM   #5
I joined the Band!
Good call, I have two sets, I'll paint a set white and see how it looks.
Old 04-27-2017, 08:27 AM   #6
I joined the Band!
Here it is with white wheels, I like the white, but the wagon wheels have too much offset and are six lug.
Old 04-27-2017, 09:20 AM   #7
A white wheel definitely looks good in contrast to the blue and black.
Old 04-27-2017, 10:03 AM   #8
Looks like a decent rig. Haven't heard or seen a whole lot about these rigs. I'm trying to find a (scale) rig for my old lady because I already have a body for her that she picked out, but its an 11.4 wheelbase. Trying to get something like the the regular cab TF2 Mojave or an old Dingo so that changing the links will not come into play as these are already 290mm (11.4) wheelbased rigs. Whats the wheelbase on this one? This might be a new option for me.
MattySlimz1987 is offline   Reply With Quote
Old 04-27-2017, 10:37 AM   #9
242mm, 252mm and 267mm it's adjustable and believe the kit comes with everything to adjust. It's a good roller for tamiya bodies.
Old 04-27-2017, 10:41 AM   #10
I joined the Band!
I'll let you know how they perform as soon as I get the electronics installed.
The factory wheelbase options are 242mm(9.5") 252mm(9.9"), and 267mm(10.5")
The Barbie Jeep project uses a CFX chassis, same as the CMX except front motor, was shortened to about 230mm(9") and it wasn't too bad.
My Land Rover CFX is about 275mm(10. wheel base.
These were all done with parts included in the kit.
Old 04-27-2017, 10:45 AM   #11
I joined the Band!
Barbie hits the rocks....
https://r.tapatalk.com/shareLink?sha...7&share_type=t
Here's the Barbie Jeep project for my wife that uses the MST CFX chassis.
Old 04-28-2017, 09:56 AM   #12
I joined the Band!
Took the Bronco out to the rockpile today and it was fun
I tried some lines I take with the other scalers and it was much more challenging.
The steering range is really tight and the narrower track width and short wheelbase make it very nimble.
It seemed like it had a lot of gear noise, I'll isolate the trans and axles to see what's wrong. The trans is all plastic gears so it's probably the mesh on the axle gears.
It seemed to roll over easily, the battery sits really high and I put on wheels with more offset than stock so it is narrower.
The receiver box is under the battery so I'm thinking about moving the receiver and mounting a shorty battery crossways in front of the motor to move the weight lower.
I also ran the tires unglued because I'm painting the others white and theses wheels are for another project.
I was able to bend the body posts back a little to address the wheels not aligning with the wheel wells.
The kits comes with three sets of springs, soft, medium, and hard, I'm running soft and the suspension seems to work well and will probably work better as I as weight.
Old 04-28-2017, 01:46 PM   #13
I joined the Band!
First, I replaced the full size battery with a shorty to reduce weight up high and it seems more stable, then I installed 1.55 Mud Thrashers and took all the currently running scalers to the rockpile and the little CMX was pretty impressive.
It couldn't quite keep up with the Ascender, it was closer to the the Komodo, and it outperformed the poor old HG.
Old 05-01-2017, 07:16 PM   #14
I joined the Band!
Here it is with 1.9 wheels painted white.
They look too big, I think I need 1.5's
Old 05-11-2017, 06:42 AM   #15
I joined the Band!
Turns out I need an M06, that's the horrible noise
Old 07-04-2017, 06:34 PM   #16
I joined the Band!
The stock tires weren't cutting it so I stole these off the D90 and cut the fenders for clearance. I also added sliders made for a CFX-w.
The tires are taller and about the same grip as stock, but the wheel offset is a little wide even with 2mm narrower hexes.
The sliders helped, the brackets bolt to the frame, but I had to trim the legs to get them closer to centerline and had to trim the length for steering clearance.
Old 12-25-2017, 08:50 AM   #17
I joined the Band!
My kid wants a hard body so I got this...
I’m gonna use the front motor and t-case from the Barbie Jeep and the printed CMS bracket.
MST CMX Bronco - Similar Threads
Chino63's MST CMX Bronco chino63 Max Speed Technology CMX 32 12-21-2018 12:25 AM
MST CMX TJ take 2 03NCTJ Max Speed Technology CMX 34 07-11-2017 06:52 PM
Mst cmx way6317 Max Speed Technology CMX 19 09-04-2016 06:51 AM
MST CMX Review shannwah General Scale Talk 0 03-07-2016 12:38 PM
