![]() | #1 |
Pebble Pounder Join Date: Dec 2016 Location: U.P.
I hear you can use use the MTX-1 Axles on the CMX and it's limited slip...any idea on parts would be needed to convert the CMX axle to limited slip? A limited slip on a these small chassis for a trail runner might work well. |
![]() | #2 |
Rock Stacker Join Date: Oct 2014 Location: New zealand
Yeah i was thinking of putting an open diff in mine too. Youll obviously need different rear axle shafts because the stock one is one piece and wouldnt allow diff action. The fronts may also need replacing as i dont know if the spider gears in the diff are driven by pins or by flats on the shafts in the mtx 1 Mst cfx Axial wraith Axial yeti 8x venom creeper ![]() |
![]() | #3 |
I"m going to look into converting using MTX-1 parts. Should be an easy swap.
![]() | #4 |
Looks like MST just came out with a conversion kit back in Dec!!! MST #210591 This should make the MST a killer trail runner now. |
How to build a Limited Slip Differential | twissted | Traxxas Crawlers | 14 | 03-26-2015 05:49 AM |
Yeti XL Limited Slip Build (or any other) | twissted | General Scale Talk | 29 | 12-27-2014 01:00 PM |
Limited Slip Differential; options? | Necrotron | Tools, and Procedures | 2 | 09-30-2014 03:28 PM |
limited slip diffs | captain kirk | Axial Wraith | 14 | 06-22-2012 10:08 PM |
limited slip tlt diff? | rash_powder | Tamiya TLT Crawlers | 12 | 03-26-2007 05:46 PM |
