03-30-2017, 11:23 AM | #1 |
Rock Stacker Join Date: Nov 2016 Location: the mountains
| Building a Transmission
So I'm starting a monster truck build. I'm doing pretty well collecting parts, but having trouble deciding what to do transmission wise, hopefully something sweet will pop up soon but if it doesn't, what are the pros and cons of buying a wraith transmission($30ish on ebay) and throwing hd gears in(which ones hold up and which ones to stay away from? and ratio?) or since I need to get it all, starting with a aluminum(again, what's good, what's not?) case and adding gears and what ever else(?) I need? Or convince me of something else I should get? So far I'm using a strc izilla chassis, wraith axles, toro 120amp esc/speed passion 13.5 motor, and a fly sky 3 channel rx/tx....still looking for a good deal on a servo, but I know I need lots of torque, probably gonna end up running about 6inch tires.
03-30-2017, 11:37 AM | #2 |
| Re: Building a Transmission
Bang for the buck I'd do an HR case, stock steel outputs, hr gears, locked up slipper eliminator and a 4 bolt motor plate from supershafty. I'm running that setup on my beater with legitimately stupid power and it's been solid. |
03-30-2017, 11:48 AM | #3 |
The Dlux Fab Burger trans are the shit, surprised meat gazer above didnt mention. |
03-30-2017, 12:07 PM | #4 |
| Re: Building a Transmission |
03-30-2017, 12:17 PM | #5 |
Says dlux and Rcbro gears instock.
03-30-2017, 12:17 PM | #6 | |
| Re: Building a Transmission Quote:
CHEAP metal gears yes. Rcbros are fully available. The MT metal gears are way fawking heavy anyway. | |
03-30-2017, 12:20 PM | #7 |
| Re: Building a Transmission how do you think id do cost wise building what you talked about vs the 80 for the hamburger. do these just mount to a wraith skid? or scx?
03-30-2017, 12:28 PM | #8 |
Either trans will mount in place of an axial trans. There is a plate with slotted holes that adapts the trans to the skid so it is adjustable fore & aft too. I've had both mounted to wraith and scx skids when we were nailing down the adapter.
03-30-2017, 12:38 PM | #9 |
Starting a monster truck build? In the crawler section? Moved. |
03-30-2017, 12:42 PM | #10 |
03-30-2017, 12:47 PM | #11 |
It's ok he is just a curmudgeon. This is the busiest place around here anymore anyways. |
03-30-2017, 12:51 PM | #12 |
I'm just trying to keep you MT weirdos out of the cool kids section. But in reality if everyone posted where ever, what's the point of dedicated sections? |
03-30-2017, 01:01 PM | #13 |
Everyone gave up their cool kid cards when they decided to play with toy trucks. |
03-30-2017, 02:14 PM | #14 |
03-30-2017, 03:34 PM | #15 |
| Re: Building a Transmission if I have wraith mip drive shafts, they will connect easy? and I assume I still need a motor mount or is that built in? sorry I'm kinda new to this whol building from scratch thing....and the rc thing in general but I'm pretty mechanical, and have done a bunch of upgrades to my scx10 and 1/16 e revo
Building a Transmission - Similar Threads | ||||
How many of you greased the transmission and axles when building the kit? | ScaleAlert | RC4WD Trail Finder 2 | 12 | 05-17-2013 09:51 PM |
Carbon Fiber Transmission Covers for VP XR10 Transmission Housing. | Tomy | Axles, Trannys, T-case | 4 | 01-20-2013 07:48 AM |
