10-22-2010, 07:18 PM | #21 |
Pebble Pounder Join Date: Apr 2010 Location: Massachusetts
10-24-2010, 02:14 PM | #22 |
So I was able to narrow the front down. Then had to cut the grille down The hood was the hardest to get right Also got the filler piece trimmed down It's all just taped in for mock up here, so it looks a little funny Then to finish off the front part of the cage I went simple since this will never really be seen since this is where I plane on cramming the electronics. |
10-24-2010, 04:55 PM | #23 |
Quarry Creeper Join Date: Dec 2009 Location: Long Island
Looks great man! I wanted to do a truggy out of my Silverado because it began to fall apart, but my skills aren't as good as yours(or even close!)
10-25-2010, 02:55 PM | #24 | |
Rock Crawler Join Date: Feb 2006 Location: jacksonville beach
on topic: lookin' good, what kind of solder do you use ? i cant seem to make a sturdy connection with my brass. Last edited by murdock; 10-25-2010 at 03:01 PM. | |
10-25-2010, 03:35 PM | #25 | |
It's nothing special, it's a bit to thick than what I should ideally be using but it works. You probably aren't using enough heat on the metal. The things you are trying to join should melt the soldier not the source of heat. | |
10-25-2010, 06:14 PM | #26 |
Quarry Creeper Join Date: Mar 2007 Location: Martins Ferry,OH
are you gonna put a stinger on it or just leave it about how it is
10-25-2010, 07:03 PM | #27 |
10-31-2010, 10:16 AM | #28 | |
60/40 .062 dia. | |
10-31-2010, 01:15 PM | #29 |
11-03-2010, 07:56 AM | #30 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Strip a 6" or so piece out of the roll, and take a hammer and beat it down to a thin strip. This will make it a lot easier to control how much solder melts into the joint at one time. Then you don't have so many blobs to file off. For a first try, your results are not bad at all. It's gonna be a heavy little truck with all that solid brass rod, you might find yourself having to sort out some suspension issues when you assemble it. It's looking good so far, finish her up! Last edited by Big Mike; 11-03-2010 at 07:58 AM. | |
11-03-2010, 01:39 PM | #31 |
Quarry Creeper Join Date: Jan 2008 Location: Calgary Canada
11-03-2010, 03:58 PM | #32 | |
Yeah it's going to be heavy. | |
11-05-2010, 05:14 PM | #33 |
bumper time. Starts with a piece of paper. Then to the metal where cutting and forming and mocking and the joining happens After a little tweaking and a couple tries I got here added the stinger First attempt ended like this second time round is much better then joined it to the rest of the chassis Then took a look with the body on The sides will have to be made out of something like bondo as making little peices like that would be very very very hard, impossible actually. Also I am going to make a tiny winch to mount on it too. |
11-07-2010, 02:03 PM | #34 |
I decided from here, I am going to get the front setup. Which would include the suspension axle and steering set up. I made some leaf springs to start. The truck im modelling off of has leafs in the front, so I figured I'd do that. Here is the main spring all set. And for size reference Then made some more leafs to make a pack Here they are taped together for now. Leaf pack for other side Both packs Something like this Here you get the idea, but there is no weight on the springs. I made them out of an old pull start spring I had from my tmaxx. Cut out the length, then heated the ends up so I could bend the ends for the eyelets. Then cut more lengths and heated those up and tweaked the arch for the second and third leafs so they would match the main leaf. they will work well, have a good spring rate. Just need to mount em and see how they work with weight on em. |
11-08-2010, 07:19 AM | #35 |
Rock Crawler Join Date: Jun 2007 Location: Nova Scotia,Canada
Just started following this and I like everything I see,gives me a lot of good ideas for the micro bodies I have and all the bras rod and sheets.Can't wait to see how this turns out... |
11-08-2010, 09:31 PM | #36 |
Rock Stacker Join Date: Nov 2010 Location: concord
is the tube ur useing holow or solid? id like to do something like that but a scout well any ways thats sick
11-08-2010, 09:34 PM | #37 | ||
I refer to it as "tube" sometimes, but it's solid rod. | ||
11-16-2010, 04:39 AM | #38 |
Pebble Pounder Join Date: Nov 2008 Location: Littleton
| :JawOnFloor: WOW! Soo epic.. I feel like I'm at the kiddie table when I come across fabrication skills like this.
11-16-2010, 12:26 PM | #39 |
11-16-2010, 03:19 PM | #40 |
Rock Stacker Join Date: Aug 2008 Location: cincinnati
looking great man keep it up!!
