09-10-2011, 09:39 AM | #1 |
| any known issues with the Losi Trekker? or must do mods?
thinking about picking up one of these little guys seems like fun! are there any known issues with these? what are popular mods? |
09-10-2011, 01:34 PM | #2 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
They;re pretty good,servos are abit dodgy,other than that,they;re good. My 4yr old s got one,treats it as 4yrs do,and hasnt broken a thing. For mods,check out the Micro MOD bible in the micro section. |
09-10-2011, 07:35 PM | #3 |
thanks i see alot of people mentionig upgradeing to a hitech metal gear servo. but they NEVER mention which one or even what size lol. any help there? is the micro mod bible not a sticky? i dont see it at the top here... thanks |
09-10-2011, 10:07 PM | #4 | |
Pebble Pounder Join Date: Jun 2011 Location: AREA 51
Micro Mod bible | |
09-12-2011, 01:12 PM | #5 | |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
1. Go LIPO get The Dynamite 7.4v 2s LIPO 180mah the batteries had the right connectors already attached and they are cheap I got mine at Amain hobbies. 2. The Lipo cut off is built into the batteries not the ESC (got this info straight from Losi) 3. The stock wheels are glued on and not real beadlocks. 4. RC4WD sells some nice aluminum beadlock and Tires http://store.rc4wd.com/Losi-Micro-cr...el_p_1105.html 5. I run my fronts with some solder wrapped around the hub and no foams and that seems to be a perfect ballance 6. The shocks on this truck as very fragile so if your going to pull them off be prepared to bend/break them. 7. The truck is 1/24 scale and most plastic model bodies are 1/20th scale 8. You can find Toyota FJ, Jeep wrangler, and Hummer bodies that fit the wheel base dead on at ToysRus (Road Rippers http://www.ebay.com/itm/Road-Rippers...-/250869183932) 9. The stock body is very scale and looks great once the stickers are pulled off 10. The Trail Trekker is an amazing little truck! I would buy it again if I had to. I also upgraded the stock servo to the Hi-Tech one and I'll have to check when I get home. I think its the HS-5055MG Here is a picture/video of my Trail Trekker and the RC4WD beadlocks and tires. The body is from Toys-r-us VIDEO Last edited by Grumpster1980; 09-12-2011 at 01:50 PM. | |
09-12-2011, 08:30 PM | #6 |
09-13-2011, 08:53 AM | #7 |
wow great post! tons of good info! many thanks!
09-13-2011, 11:45 AM | #8 |
09-20-2011, 08:09 PM | #9 |
Rock Stacker Join Date: Apr 2005 Location: Queens, NYC
I'm also thinking about picking up one of these things to make a scale rig of my real rig ;) http://www.youtube.com/watch?v=UgUAuEYHXwI |
09-21-2011, 12:10 PM | #10 |
Newbie Join Date: Sep 2011 Location: san antonio
tires and weights a must to have fun i say no lipos, its a crawler not supposed to be fast plus the batteries dont last long i have the orginal batt. and i out last two of my buddies lipos an still crawl anywhere. (almost lol) save the money an just learn this "tire placement" an u will be happy
09-28-2011, 11:06 PM | #11 | |
09-29-2011, 06:07 AM | #12 | |
Pebble Pounder Join Date: Feb 2011 Location: Bulgaria
But there are some isues of using 1s: 1.No low voltage cutoff 2.if you are runing too heavy tires or your overal rig is too heavy you dont want a 1s.You need more torque. 3.Ive heard that if you upgrade the servo (hitec,t-pro,...) Then you woudn't have enought voltage to ster properly. And remember - It is all about taste | |
10-02-2011, 03:26 PM | #13 | |
Standard 6 cell NIMH battery is 7.2v and a 2s LIPO is 7.4v If people want to run NIMH then have at it. My problem is when someone gives misinformation that can lead people down the wrong path. If you want slower speeds that is what the throttle is for. I run a 2s in my Micro, AX10, SCX10, and CC-01 and all of my rigs can crawl as slow as a snail so I do not understand the argument that a 2s makes your rig to fast. The ESC and Throttle governs how fast you go. Now if you talking about 3s or higher (11.1v) then yes it would be overkill for crawling but once again you could use throttle control to go as slow or fast as you wanted. The proof is in this video using a 2s 800mah Lipo with the stock ESC Last edited by Grumpster1980; 10-02-2011 at 06:12 PM. | |
10-03-2011, 04:39 AM | #14 |
I agree.But the stock battery is 4.2 v (4 cell)i havent seen a 6 cell in a trekker yet.And try to go very slow with a 1s and with a 2s and you will see the diference. |
10-03-2011, 11:42 AM | #15 | |
That being said I can still have my truck move at a snails pace with throttle control. Last edited by Grumpster1980; 10-03-2011 at 12:04 PM. | |
