03-14-2012, 12:12 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Roswell
| Micro Pete A.K.A. Crawler Hauler
I decided to post this here for those of you that might not see it on the other site. I have always wanted a rc 18 wheeler but never had the space or the money to do a 14th scale the way I want. Recently I have been using the Losi Micro Crawler axles, transmission and reciever/speed control along with plastic model kits to make scale trucks and realized these would be perfect for a 18 wheeler build. Of course I was not first to figure this out. I have been planning and researching this for a year on and off and I don't really mess with micros during the summer and the winter has been mild here so I got a late start. I was thinking I was going to do a brass frame but decided the plastic one will work good with some extra styrene reinforcing and crossmembers and alot of glue, plus maybe I will see some torque twist when pulling heavy loads. I also extended it 2". |
03-14-2012, 10:20 AM | #2 |
RCC Addict Join Date: Mar 2011 Location: easton
i never thaught of that and i have the same kit. subscribed |
03-14-2012, 10:31 AM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: North Alabama
| Re: Micro Pete A.K.A. Crawler Hauler
I seen this kit the other day at hobbylobby and thought about getting it for my 6x6. Looks good. Do you plan on making it a 4x6 or 6x6?
03-14-2012, 11:32 AM | #4 |
Newbie Join Date: Mar 2012 Location: Coruscant, in the Jedi Temple
pretty cool idea. hope you can get it running soon and my only concern is that they dont carry rc stuff. |
03-14-2012, 12:47 PM | #5 |
| Re: Micro Pete A.K.A. Crawler Hauler You should build yours, it's a fun build with lots of options. I will be making it a 4x6, going for a bit of a hotrod look. I will be using it to transport my crawlers so I didn't want it to have a crawler look. Thats why I call it Crawler Hauler in case some of you didn't get it. |
03-14-2012, 12:49 PM | #6 |
| Re: Micro Pete A.K.A. Crawler Hauler For the rear suspension I am using leaf springs made frome a 1/8 scale engine pullstart spring, 1/16" steel for the airbag mounts and simulated airbags with compression springs covered with twist balloons. They are attached with small pins and I uesd heat shrink tubing for the bushings. The axles are from the Losi Micro Crawler and are easy to connect together using brass rod and tube brazed together, plus I am not the first to do it. Next I made panhard bars out of lexan so they would flex and I wouldn't need a ball joint. It is also attached with a small pin.The axle wideners are 4mm feather shafts for a 450 size helicopter. I cut them to length and drilled them out and threaded them. They are perfect for the wheels. The drive pins are nails cut to length. |
03-14-2012, 01:06 PM | #7 |
Newbie Join Date: Feb 2011 Location: stockton
Nice work on the rear suspension it look very sacle. What front axle are you using?
03-14-2012, 08:55 PM | #8 |
Rock Stacker Join Date: Dec 2011 Location: Colorado Springs
awesome, digging the rear bags. nice work. |
03-15-2012, 11:38 AM | #9 |
Quarry Creeper Join Date: Jun 2004 Location: Louisville
I think this project, hands down, is the most awesome and unique Micro project ever! I can't wait to see it completed...and action pics and vids!
03-15-2012, 10:04 PM | #10 |
| Re: Micro Pete A.K.A. Crawler Hauler For the front end I used the same spring steel and 1/16" steel for the hangers and they are attached with a small pin and I used heat shrink tubing for the bushings. Airbags with compression springs covered with a peice of a twist balloon. The axle is cast alloy from Kit Form Services. Did a quick weight test on the frame. Lipo's aren't heavy enough. |
03-15-2012, 11:11 PM | #11 |
i may build mine. if i do it will be a but different....well ALOT different
03-17-2012, 07:35 PM | #12 |
RCC Addict Join Date: Nov 2007 Location: -
Wow, very very nice job...nice to see something different. Any updates?
03-20-2012, 11:57 AM | #13 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: Micro Pete A.K.A. Crawler Hauler Quote:
Stunning work so far. The rear suspension looks fantastic... Subscribed for sure... | |
03-20-2012, 05:13 PM | #14 |
Thanks, glad you guys like it. The Transmission is also from a Losi Micro Crawler and I screwed it to the frame on one side and used a peice of styrene to connect it to the frame on the other side for added strength. I plan to use a 70-90 turn, neo mag 130 motor but for now I have the stock one. For the driveshaft I used a peice of antenna, it's small, strong and somewhat light weight. Glued it to one side and slotted the other end and put a pin in it so it could slide. |
03-21-2012, 02:30 PM | #15 |
MORE!! This is going to be a good one I can tell already...
03-21-2012, 05:14 PM | #16 |
looking good so far! its making me want to build mine as a 4x4 crawler! Sent from my iPod touch using Tapatalk |
03-21-2012, 09:47 PM | #17 |
| Re: Micro Pete A.K.A. Crawler Hauler |
03-22-2012, 12:37 AM | #18 |
03-22-2012, 10:26 AM | #19 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
i think cobra meant he was going to "bob" his truck.
03-22-2012, 11:36 AM | #20 |
Sweet! More progress! How are you going to mount the servo?
Micro Pete A.K.A. Crawler Hauler - Similar Threads | ||||
New Crawler Course ST PETE>? | skee | Florida | 68 | 08-08-2013 03:38 PM |
New crawler hauler | freetimecrawler | Chit Chat | 8 | 06-03-2006 08:10 AM |
My crawler hauler | freetimecrawler | Chit Chat | 11 | 05-14-2006 07:18 PM |
Crawler Hauler | Unimoger | Chit Chat | 36 | 04-22-2006 08:33 PM |
