Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: my trekker
Old 12-07-2012, 09:25 PM   #1
Default my trekker
hey i need sugestions for motor or motor esc combo to power this, tired of stock and want some fresh power
MaD222 is offline   Reply With Quote
Old 12-07-2012, 09:55 PM   #2
Default Re: my trekker
nm, a quick google came up with the 180 stroker........ sweet will be ordering this up on payday for sure....
Old 12-07-2012, 10:05 PM   #3
The Stroker kit is the way to go. And esc wise. Tekin has a b1r that would be a nice lipo and adjustable esc. But It's kinda $$. Losi has other micro esc avail.
jeepguy5 is offline   Reply With Quote
Old 12-07-2012, 10:13 PM   #4
ya i was lookin at some tekin's earlier, look cool.....im running 450 mah nanotech right now, even on the stock esc/motor im gettin over 25-30 min run times, although its mostly easy crawling, and the motor still gets smokin hot, but still goin......lol
Old 12-07-2012, 10:26 PM   #5
Nice rig!
The stroker I'm running is 90t and runs absolutely cool after 30 minutes of axle breaking crawling. It is still running perfectly on the stock esc. I have one on a Mamba Micro esc and it is a bit nicer due to the tunability but with this much power there is little noticable difference. I just hate having to fit a speed control with a seperate receiver inside the micro's...it's just so tight.
Just an fyi...all big block and stroker kits are on hold due to the lack of 59t gears out on the market. As soon as they show back up they will be available.
On another note: if you have never tried a 90t losi rewound motor you might be suprised. They stay way cooler than the stock wind and give longer run times. Power is pleanty for most people and the fit is stock. (and they are WAY cheaper)
DANALLY is offline   Reply With Quote
Old 12-07-2012, 10:26 PM   #6
I think the stock ESC is fine with the stroker motor, it doesnt even get warm and plenty of run time on 350mah lipos
spoo76 is offline   Reply With Quote
Old 12-07-2012, 10:44 PM   #7
thats good to know, i will stay with the stocker.....as i have a brand new one in pckg waiting just in case.....
still need to finish my bumpers as well as get the 65mg servo this one i have isnt doing it!!!
Old 12-12-2012, 01:33 PM   #8
Throw another vote up for the stock ESC/RX combo. Running mine with a Danally Big Block (130 IIRC) and Hitec HS65MG servo on a GensAce 450m2s and get tons of power and 30+ minutes of good run time. No reason to change out the ESC if it ain't broke. Just decase it for some weight savings.....although not much.
Sh0rtBus is offline   Reply With Quote
Old 12-31-2012, 07:10 AM   #9
Does that metal body weight down your shocks significantly?
Do you get a lot of body roll?
razors 33 is offline   Reply With Quote
Old 12-31-2012, 09:21 AM   #10
i have a new thread with a fresh rebuild of this......but i had changed to stiffer springs, so no body roll, but wasnt very agile in the rocks, hence the rebuild with model kit
Old 12-31-2012, 10:11 AM   #11
Found new thread
Where did u get stiffer springs? I am pondering adding pre load to stock springs but if I can get better I might as well
my trekker - Similar Threads
My new Trekker... JavelinSST390 Micro Scale Rigs 14 10-08-2012 09:58 AM
Question for Trekker (or Trekker suspension link) owners Markhpnc Losi Micro-Rock Crawler 9 08-12-2011 05:43 PM
My new Trekker exile182 Losi Micro-Rock Crawler 5 05-11-2011 03:14 AM
