Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Caged tj
Old 06-03-2016, 05:03 PM   #1
Default Caged tj
Well ive had this body for a few months now. New bright 1/20 tj I believe. Full interior no top. It was black with the false mud on it. Anyways I knew it would be perfect so I scooped it up. Finally got around to doing something with it.
Stock losi drivetrain
Will be buying some of Jim Frey's wheels and a ddt motor. Post a few pics here and there on the fb page figured I'd post it here as well.
Fenders already chopped up a tad
Decided to go with an 80% caged build
Brass frame started
Post more shortly
Sent from my SCH-I535 using Tapatalk
heavychevy is offline   Reply With Quote
Old 06-03-2016, 05:16 PM   #2
Default Re: Caged tj
And yes the rear links are getting extended...a good bit
Old 06-03-2016, 05:51 PM   #3
Old 06-08-2016, 12:07 PM   #4
Old 06-09-2016, 11:40 AM   #5
Looking good I need to try my hand at some brass work. what dia tubing are you using?
Sparks1337 is offline   Reply With Quote
Old 06-17-2016, 08:52 PM   #6
Just now saw this! Its 3/32 solid rod
Old 06-17-2016, 08:57 PM   #7
Update! So I didnt like the losi gear so I traded it off for a sumo. This will give me a lower crawling speed. Wider axles so I can use less offset wheels. And just better looking.
Stock sumo trans
Chop chop
Gear motor going up front so I can keep an interior
Front links mocked up. Cms made.
Old 06-18-2016, 08:59 AM   #8
Cool cheers
Sent from my GT-I8190N using Tapatalk
Old 06-30-2016, 06:09 PM   #9
Got wheels and lockouts in the mail a few days ago. Been busy cleaning up the house and havent gotten to install. Pics soon!
Old 09-01-2016, 01:06 PM   #10
That's pretty sweet would aluminum be a little lighter unless it's better to have a little more weight in the frame
suttons10 is offline   Reply With Quote
Caged tj - Similar Threads
caged creeper tulsa Venom Creeper 16 03-02-2011 08:57 PM
Caged FJ-40 build HotRodJosh 2.2 Scale Rigs 26 11-11-2009 12:54 PM
