02-13-2017, 06:38 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: monson
| Orlandoo P01 and A01 tips, mods, advice and ideas
So I just finished assembling the jeep, (what a cool kit). Anyway there were a couple sticking points that I needed direction on, well, I thought it might be cool to start a thread with ideas and such for people just getting started. So, if you have an idea post pics with brief description for others to use. I'll start off with my wheel mod. Sent from my SM-G900V using Tapatalk |
02-13-2017, 07:03 PM | #2 |
| Re: Orlandoo P01 and A01 tips, mods, advice and ideas
Here's my wheel mod. First off I started with losi micro desert truck wheels and a 1/2" spade bit. You can cut by hand, but it it's easier with a hand drill. Use light pressure. A bit of trimming and sanding and Next choose your center, (any of the Orlandoo wheels). They should fit nearly flush in the back. I used hot glue gun to hold them together, I'll probably "goop" or epoxy them later, or not. And there's your new look. Excuse the lame build I hate painting. Sent from my SM-G900V using Tapatalk |
02-13-2017, 07:50 PM | #3 |
Up next is wiring on the A01 jeep. It took a few tries. ESC, motor and servo are typical recommended from HobbyKing website. The battery is a rewired (bought wrong plug) eflite 120mah 2s. Sent from my SM-G900V using Tapatalk |
02-14-2017, 10:48 AM | #4 |
Newbie Join Date: Nov 2009 Location: FRANCE
| Re: Orlandoo P01 and A01 tips, mods, advice and ideas |
02-15-2017, 05:56 PM | #5 |
New wheels came in tonight, makes them look more like original losi wheel. Wheel is Orlandoo GA0005 Sent from my SM-G900V using Tapatalk |
02-16-2017, 05:13 AM | #6 |
Here's how I stuffed in the electronics on the P01. Sent from my SM-G900V using Tapatalk |
03-05-2017, 01:23 PM | #7 |
Here's my advice for painting, don't, leave it white. This was way too much of a pain. Unless you're a teenager buy a pair of head magnifiers, it is hard to see those little parts. Sent from my SM-G900V using Tapatalk |
03-08-2017, 08:09 PM | #8 |
So this is advice but more looking for advice. I assumed (apparently incorrectly) that the Chinese translation for "seem glue" meant model glue. Well after a run all the little bits I glued on, started falling off, and showed no normal signs of melt, like styrene. So, what do you all use for glue on these little dudes? Sent from my SM-G900V using Tapatalk |
03-08-2017, 08:18 PM | #9 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
CA glue. It's basically superglue, and can be found at your local hobby store.
03-11-2017, 02:35 PM | #10 |
Rock Stacker Join Date: Feb 2017 Location: USA
Here is one for ya. Level the truck up! I cant help but notice all Jeeps are pointing nose up. It looks like sagging rear springs. What I have done was drilling new holes for upper shock mounts. And now it looks like this: Also for all of you struggling to fit stock wheels on due to tightness these aluminum replacements from RCMart fit snug. |
04-11-2017, 01:38 PM | #11 |
Here's a quick way to temporarily(permanently) mount modified losi DT wheels. O-ring and OH wheel Place in groove on back side Press in Done. The O-Ring holds it centered and gives enough friction to keep it from slipping. Sent from my SM-G900V using Tapatalk Last edited by 500swmag; 04-11-2017 at 01:41 PM. |
04-11-2017, 07:32 PM | #12 | |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
| Re: Orlandoo P01 and A01 tips, mods, advice and ideas Quote:
So, with the O-ring I can fit the DT tires on the OH rims? The only tires I can find are premounted to black chrome DT rims, will this option work like the set in the OPs rig with the drill bit? | |
04-11-2017, 07:35 PM | #13 |
Yes, I should have clarified you need to do the first part of this post and drill out the DT wheels. Sent from my SM-G900V using Tapatalk |
04-11-2017, 09:55 PM | #14 |
Newbie Join Date: Mar 2016 Location: Sacramento
I like the look of the Micro DT wheels. Will the stock wheels fit into the DT wheels without having to cut out the face of the DT wheels?
04-12-2017, 04:56 AM | #15 |
No, drill it out, its super easy, just takes some time to clean up.
11-29-2018, 03:04 PM | #16 |
Newbie Join Date: Nov 2018 Location: Spain
Hello, I was interested to do the Losi micro dt wheel mod but it's impossible to find them, they're out of stock EVERYWHERE and I think they don't produce them anymore . Do you know of any other similar wheels I could use for the orlandoo jeep? Thanks a lot for your help!
11-29-2018, 06:16 PM | #17 |
Pebble Pounder Join Date: Mar 2014 Location: Australia
I dont recommend the DT wheel mod.... well depends if you like to turn or not
11-30-2018, 03:38 PM | #18 |
Ok, thanks for the answer, didn't know that the turning radius was reduced. Will look into the mod to lift it a bit more and get extra ground clearance, is there any way to make the wheel base a bit wider? Thanks again! |
Orlandoo P01 and A01 tips, mods, advice and ideas - Similar Threads | ||||
R1 Mods, Tips and tricks | cytogen | G-Made Crawlers | 24 | 12-07-2019 09:54 AM |
Dingo Kit - My first build. Any tips/advice? What mods are worth doing? | LeadFootCaliKiid | Axial SCX-10 | 2 | 01-06-2014 03:51 PM |
6x6 SCX10 ideas and tips. | MSH | Axial SCX-10 | 5 | 02-24-2010 11:51 AM |
tips,tricks and mods | TOYUTAH | Losi Mini-Rock Crawler | 50 | 12-23-2008 10:47 PM |
