02-15-2017, 05:48 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
| Ordered the Orlandoo F150 today
I ordered my first micro today, the Orlandoo F150. Is there anything I should know before it shows up and I get started on it? Lessons learned, tips, tricks etc?
02-15-2017, 06:35 PM | #2 |
Did you get a motor, ESC, and servo? I used a cheap 10a ESC and one of the smallest, non low voltage servos I could find. Removed the case from a Rx and tucked it all in the cab. |
02-15-2017, 07:37 PM | #3 |
| Re: Ordered the Orlandoo F150 today
I bought the full kit so its supposed to have everything but the receiver. I was wondering how I might cram a receiver in the cab, removing the cover is genius, thanks!
02-16-2017, 05:23 AM | #4 |
Rock Crawler Join Date: Nov 2016 Location: Vienna Austria
Hi, gear pusher helped me a lot during assembly. I have two and used both: https://hobbyking.com/de_de/bearing-puller-tool.html And a small one like this (but with smaller diameters - can't find it right now on HK): https://hobbyking.com/de_de/internal...r-12-14mm.html Furthermore: Do NOT use the 1.4 mm drill delivered with the set. I used 1.2 mm - but probably 1.1 would even have been better. Use CA or Epoxy, put a little bit into the holes befor screwing the linkage-balls in. Walter |
02-16-2017, 10:09 AM | #5 |
Rock Crawler Join Date: Jan 2007 Location: monson
| Re: Ordered the Orlandoo F150 today |
02-16-2017, 03:56 PM | #6 |
Pebble Pounder Join Date: Feb 2012 Location: Aurora
02-18-2017, 06:02 PM | #7 |
I got the chassis put together today. Holy crap did I underestimate how challenging this would be. I stripped a couple of the ball head studs and glued them, hopefully they'll hold. I definitely need a dedicated .9mm driver. These little things could get addictive for sure.
02-18-2017, 11:10 PM | #8 | |
| Re: Ordered the Orlandoo F150 today Quote:
Amazon sells a couple nice sets... I stripped a couple in my kit with the supplied wrench, ended up ordering new plastic, and a good set of micro drivers, shoulda done that the first time. They will work loose. | |
02-20-2017, 06:07 PM | #9 |
I got it wrapped up today. The paint didn't go so great but I can live with it, I'll do better on the next one. The only other issue I had was installing the four inbound ball studs that the upper links connect to on the chassis. Not sure how I'll try to do those differently next time but they're a pain. Here's a short video I put together today. My hunting partner Greg drives a lifted, blacked out F150 and he was impressed with the scale version I did of my Ram. The sole reason I went this route was to put this video together to screw with him but I'm glad I did it and I'm hooked on the micros now. https://www.youtube.com/watch?v=M5QXs3ZFrho |
03-01-2017, 07:06 PM | #10 |
Used two sets of Losi Micro DT shocks and used the two shorter shocks from each set to lift it up a bit. I couldn't get them to rotate freely on the ball heads so I removed the ball heads, opened up the threaded holes and installed the shocks using M1.5 screws instead. The shocks needed spaced out a bit wider on the axles so I cut and used the rod ends from the original shocks as spacers. They run much smoother than the original shocks and I didn't screw them down tight so they allow for good articulation as well. I also drilled out a set of Mini DT wheels and glued a set of the 10 spoke wheels inside them to try to replicate the XD wheels on my buddy's F150. I've got a 2.2g servo on the way, not sure how I'm going to install it yet. |
Ordered the Orlandoo F150 today - Similar Threads | ||||
just ordered my SCX10 today, Im a newbie to Rock Crawling ... HELP!! | upNComer | Axial SCX-10 | 7 | 04-07-2014 06:13 AM |
Ordered my RS10 today! | Capecrawler | Redcat Crawlers | 54 | 11-04-2010 08:20 PM |
Just ordered an axial scorpion rtr today!! | MGT3.O | Axial AX-10 Scorpion | 1 | 03-01-2010 12:48 PM |
ordered some more parts for the wk today | iceman320 | HPI Wheely King | 2 | 02-05-2008 08:23 PM |
just ordered X-Factor 2 today.... | Vitamin_J | XTM Crawler | 0 | 01-08-2005 11:44 PM |
