![]() | #1 |
Pebble Pounder Join Date: Mar 2017 Location: Smyrna
Just got one so I thought I'd show it off ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk |
![]() | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Nice. I went with blue as well. It should hopefully get here Friday. Sent from my SM-N900T using Tapatalk |
![]() | #3 |
I went with the stock gelande wheels and tires ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk |
![]() | #4 |
Rock Stacker Join Date: Apr 2017 Location: RI
Whats that white truck? The truggy looking thing.
![]() | #5 |
![]() | #6 |
Rock Stacker Join Date: Jan 2009 Location: Carthage
Did you gear the ecx down at all?
![]() | #7 |
| ![]() Just got done putting a hbx/sumo trans in it new esc and the gelande dive shafts the servo is next then the upper links to get a better drive shaft angle I tried the smaller pinion but it wasn't enough Sent from my SAMSUNG-SM-J320A using Tapatalk |
![]() | #8 |
The sumo transmission with the 3 gears? That has almost no reduction and will make the ECX fast as hell Sent from my SM-N900T using Tapatalk |
![]() | #9 |
![]() | #10 |
I'm aware of it, it's basically a sumo crawler. I reviewed them on here years ago. I wasn't concerned with the strength. What I'm saying is the sumo and HBX have all the reduction in the gear head motor, not the transmission. The transmission is almost 1:1. If you swap a sumo transmission onto the ECX axles it will be crazy fast with low torque and not easy to control. You'd probably want some kind of reduction even if you're building a fast rock bouncer or mud truck. Sent from my SM-N900T using Tapatalk |
![]() | #11 |
| ![]() Hmmm that stinks. I haven’t even looked to see what the trans consists of yet but I might look into printing some gears.
![]() | #12 | |
| ![]() Quote:
Sent from my SAMSUNG-SM-J320A using Tapatalk | |
![]() | #13 |
Quarry Creeper Join Date: Dec 2016 Location: Womelsdorf
hit me up. I could use a sumo trans with my losi axles ![]() |
![]() | #14 |
![]() | #15 |
What do you guys think ![]() ![]() Sent from my SAMSUNG-SM-J320A using Tapatalk |
![]() | #16 |
Pebble Pounder Join Date: Aug 2007 Location: london
What about swapping the new rc4wd micro transfer into it?
![]() | #17 |
![]() | #18 |
Quarry Creeper Join Date: Dec 2007 Location: Central Florida
what tires do you have on your rocksta I been looking for bigger ones for mine since the miclaws are no longer made. also what are those last tire on the barrage I like the look of those ones. |
![]() | #19 |
I run the scrambler on my rocksta and on the barrage are the Mickey Thompson on ftx rims which are wider than most wheels makes them look a little different Sent from my SAMSUNG-SM-J320A using Tapatalk |
![]() | #20 |
thanks, Are those Scrambler bigger than the miclaw tires? I dont recall seeing them before they must have been released recently or been out of stock forever. so far which one is working better on the barrage? |
ECX 1/24 Barrage | casper975 | Chit Chat | 8 | 12-10-2017 12:39 PM |
