Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Any info on these China tires...?
Old 06-09-2018, 09:01 AM   #1
Default Any info on these China tires...?
I spotted this rig when it first came out and thought it had potential but the price was and is still a little high for me. It’s listed as a 1/18 though it has micro style axles and tranny. But this is about the tires.
The tires for it are reportedly 59mm tall. Width still unknown as well as the wheel size. I’m hoping it’s a 1” wheel since I took a $5.79 gamble and ordered a set. For -$6 it’s a worthy gamble for a non-scale build I’ve got in the works.
https://www.banggood.com/Hub-With-Ti...p-1270952.html
Brake Weight is offline   Reply With Quote
Old 06-09-2018, 12:43 PM   #2
Default Re: Any info on these China tires...?
I remember seeing them at a gas station and a few youtube videos. They always looked like pretty tall tires, but someone confirmed the wheels are bigger than 1" not sure how soft they are either. They may fit a WPL wheel though.
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 06-09-2018, 12:57 PM   #3
Well, I double checked with Aaron and they do fit a 1" wheel.
Old 06-09-2018, 12:58 PM   #4
Nice. I may order a second set then.
Old 06-10-2018, 11:06 AM   #5
For the price can't go wrong.they work well and have mounted on basher rocksta rims
1tuffmj is offline   Reply With Quote
Old 06-10-2018, 07:21 PM   #6
Those tires are a tight fit on standard micro 1.0's. They are pretty wide, but when there on a micro wheel they have a nice narrower taller look, about the same height as the scramblers. i'd have to measure tomorrow if need be. I mounted some scramblers on mine. I snagged my prc when it went on sale a while back. As far as the rig goes it was worth every penny. Nice electronics etc..
MGCrawler is offline   Reply With Quote
Old 06-10-2018, 07:23 PM   #7
How've you been man? I've seen these rigs in boxes at stores, but curious how well they scale up to other 1/20 and 1/18 like the mini gelande
Old 06-12-2018, 11:12 AM   #8
I joined the Band!
what terrain do these work well on? how are they vs Miclaws?
RootBreaker is offline   Reply With Quote
Old 06-12-2018, 07:13 PM   #9
Doing well thanks, hope you been good. The PRC axles are wider than the gelande's by a good bit. The steering angle up front is unreal. The steering linkages get in the way a bit, but my biggest bummer is the drive "hex" which is actually a square so no micro wheels. The scramblers look good on the factory wheels anyway.
These tires are good in most terrain. Original purpose was for rock crawlin' but would make pretty nice mudder tires etc..
Old 06-27-2018, 05:18 PM   #10
The compound is not nearly as soft as the Scrambler. Almost as soft as the MiClow but the carcass is much thicker. I’d say it almost as comparable as the Axial BFGs that came on the Yeti as for a comparison as to how the thick carcass feels. Albeit a 1.0 compared to a 2.2 is apples and oranges.
Old 06-27-2018, 09:16 PM   #11
Old 06-27-2018, 09:17 PM   #12
Old 06-29-2018, 06:41 PM   #13
I haven’t tried these yet but I think I’ll like them. Running the MiClows foamless lead to them often times folding up and walking under obstacles that with a foam they would crawl over. But if they had a foam then often times they would be too stiff to conform to other obstacles. They need a sweet CI dual stage.... But these China tires are a slightly harder rubber compound and larger lugs as well. I will see in a few days just how they’ll stack up to a light rig like my Goat.
Old 06-29-2018, 06:43 PM   #14
C.I has micro/mini foams available in different firmness levels
Old 06-29-2018, 07:55 PM   #15
You’re right. I was thinking they only offered the 1.55/1.7 sizes as their small foams. For $3 I may just have to try a set. They’d definitely be better than stock foams and better than no foams.
http://crawlerinnovations.com/lil-nova/micro-foams/
Old 07-30-2018, 09:01 PM   #16
Just a little follow up.
I’ve ran these China tires a fair bit and they don’t conform well at all even without foams. I’ve weighted both the tire with BBs and the wheel with solder and they just don’t work half as well as the MiClows.
Recently I put the Scramblers on some of those wide offset beadlock HBX wheels and weighted the wheels some. I put the foams in as well but the Goat chassis just doesn’t have enough weight to make the foams work. So I pulled the foams and added some ball bearings and I am impressed. Even with the lack of large lugs like the MiClows they have our performed them. I pulled some lines tonight I didn’t think were possible. Partly due to the ball bearings but also the tire seemed to wrap around obstacles much better than the MiClows. That and the full offset wheels allowed some amazing side hill action.
The only issue now is that these axles came from a Trekker way before they were discontinued and I never greased them. I’m getting some binding now and will hopefully get a chance to open them tomorrow. They’ll get some grease and I hope they’re not ruined since they have a fair amount of run time. My 250mAh 2s batteries are also lacking from being left charged all the time. So I’ll source a few more soon. Anything larger and the Goat feels top heavy.
Old 08-09-2018, 07:35 AM   #17
I opened the axles to find them in good shape but just a dab of grease. So I packed the grease into them and put them back together. Took it back out and it was doing better sound wise but was now looking like it could be the motor. It was stalling on steep inclines and I'd have to stop, wait a second or two, and then continue on with throttle. A few minutes later the pinion split in two so it's down until I find a replacement gear. I'm thinking of using the motor from my unused Barrage tranny since it's a long can and I have the room to fit it.
Old 08-09-2018, 09:32 AM   #18
Originally Posted by Brake Weight View Post
I like the looks of your 'Goat' who make it? Big fan of 4WS. Is it 1/18 scale?
Gramps is offline   Reply With Quote
Old 08-09-2018, 04:44 PM   #19
http://lynxmicrotech.com/
Lower prices
Old 12-07-2020, 01:06 PM   #20
Hello,
can anybody tell me, where can I buy the OP tires for FS-73501 / Reely Hiker SFX / Partner Racing QX-4 ?
I only found the glued set with rims:
https://www.aliexpress.com/item/32986912937.html
22 USD
or:
https://item.taobao.com/item.htm?id=631195076028
13 USD
I would like to buy only tires like here:
https://www.aliexpress.com/item/32856784322.html
GarrTog is offline   Reply With Quote
Any info on these China tires...? - Similar Threads
Cheap Tires from China... psn Tires and Wheels 44 03-19-2019 06:39 AM
Need info on putting a China 2 door jk on a gelade/d90 frame thunder-dumpling General Scale Talk 1 03-18-2017 05:22 AM
On road tires info wanted ... guzzio Vaterra Twin Hammers 4 11-21-2016 01:38 PM
Info on these tires crawlman Tires and Wheels 4 01-23-2009 01:51 PM
any info on these tires? fordzilla1 Chit Chat 18 05-23-2007 04:47 PM
