06-28-2018, 10:53 AM | #1 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
| Mini Crawler Indoor scale Course
Update 1: I started this project one year ago as a means to enjoy my then recently purchased 1/25 Pro-Line Ambush during our long Canadian winter months, but got pushed back because of my D90 Winch Challenge Pickup build (D90 Winch Challenge Pickup). After looking at what had been done by fellow mini/micro crawler owners on the net, I settled on making a “portable” 2’ x 4’ mini crawler indoor scale course. The foundation of my indoor course consist of: - 1” thick blue foam insulation boards; - A variety of recycled cardboard packaging for laserjet printer toners (Thank you, office recycling bin!); - Plastic mesh from the dollar store (I think it’s supposed to be used in DIY craft/home décor?!?); - Expanding foam to fill in voids; - One small wood log; - 3M Super 77 Spray Adhesive; and - Tons of hot glue sticks. Cardboard packaging pieces where hot glued to the foam board to form the rough shape of the course, as well as foam shapes, cardboard patches and cut-out sections of the packaging, and carve out details in the foam, add obstacles and generally refine the shape of the course. The plastic green mesh was added as a backing for whatever surface finish I will apply, either modified cement, plaster, truck bed liner, etc. As part of the planning of the scale course layout, I am forecasting 6 differing access points; the 2 routes in green are direct access onto the mountain, while the 4 pink routes will be bridges or ramps. D |
06-28-2018, 11:04 AM | #2 |
| Re: Mini Crawler Indoor scale Course
I keep putting off building myself a micro course. I bore easily after a few passes and move on especially when outdoors. I rarely repeat an obstacle unless there are multiple lines to be made I wish someone would make a modular crawly course similar to Legos. Compressed/bricked recycled paper would be ideal. |
06-28-2018, 07:31 PM | #3 | |
| Re: Mini Crawler Indoor scale Course Quote:
07-03-2018, 06:59 AM | #4 |
Update 2: Now that my D90 Winch Challenge Pickup build is near “completed” I have some progress on my mini crawler indoor scale course; the plastic mesh backing is finished as are the obstacles and carved access ramps into the foam in order to drive the crawlers onto the course directly from the ground. Support structures were added where platforms, bridges and ramps will be installed as to get onto and move from one mountain to the other. Utilizing branches from my cedar edge, a “make shift” section of the first ramp was built. The grotto/garage was refined with details on the inside walls. D |
07-07-2018, 09:21 AM | #5 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Did you use a full 4x8 sheet of foam board?
07-09-2018, 08:31 AM | #6 |
| Re: Mini Crawler Indoor scale Course No, I used a 1" thick standard 2x8' sheet that I cut in half to get a 2x4' base.
07-09-2018, 08:36 AM | #7 |
| Re: Mini Crawler Indoor scale Course |
07-16-2018, 07:06 AM | #8 |
07-18-2018, 09:04 AM | #9 |
Update 5: I decided to cover the whole structure with plaster cloth instead of modified cement as to keep the overall weight down. Post-plastering, I am still uncertain if I will coat the plaster with bed liner, a thin layers of parging cement or other surface finish that provided grip and abrasion resistance. The plastering finished and curing for a few days in the basement. D |
02-28-2019, 09:03 AM | #10 |
Newbie Join Date: Feb 2019 Location: Olathe
This is a great build, and exactly like what I'm wanting to build. Did you ever "finish" it? Any pic's or info about how it worked out is greatly appreciated. |
02-28-2019, 09:41 AM | #11 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Looks great! Any further updates?
02-28-2019, 05:57 PM | #12 |
Update, update, update! Sorry i know this thread is way old, but i still want to know. Sent from my SM-G965U using Tapatalk |
Mini Crawler Indoor scale Course - Similar Threads | ||||
Ftx 1/24 outback mini scale crawler | MattTheGenus | Micro Scale Rigs | 21 | 11-10-2017 04:30 PM |
Moto's mini pro indoor crawler | motoman96 | Losi Mini-Rock Crawler | 3 | 07-31-2014 02:08 PM |
my new indoor mini course. | elsewhere | North Dakota | 4 | 01-20-2013 09:00 AM |
Indoor Losi Mini Crawler Legue | schmenzer | Wisconsin | 15 | 09-25-2008 08:38 PM |
