Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Wheel hex source...?
Old 07-27-2018, 05:33 AM   #1
Default Wheel hex source...?
Anyone know of a source for the 7mm hex for mounting wheels? I’ve lost one in my junk room and now have one crawler down. I can’t seem to find any on fleaBay or the China sites.
Brake Weight is offline   Reply With Quote
Old 07-27-2018, 06:13 AM   #2
Default Re: Wheel hex source...?
Im using VP clamping hexes.
Lockedup rc has wheel hexes as well
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 07-27-2018, 06:29 AM   #3
A few options pop up from various vehicles when I type in 7mm hex into Google. Other than that maybe searching for one of the specific vehicle hexes. There's also the brass hex extensions on eBay and possibly RC4WD may sell gelande metal hexes separately
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 07-27-2018, 06:36 AM   #4
Yeah ignore my post...
I was thinking of 12mm hex, not fully awake yet
Old 07-27-2018, 07:14 AM   #5
Moderator
JatoTheRipper's Avatar
Do you mean 7mm wide?
Traxxas aluminum ones are great, cheap, and readily available.
Old 07-27-2018, 07:21 AM   #6
The 7mm micro hexes. Trail Trekker, LMcC, HBX, RGT, whatever brand of aftermarket. I’ll have another look later when I get a chance.
Old 07-27-2018, 07:35 AM   #7
Don't forget, the trekker is 7 mm but has a slightly thicker hex than the others to give it the extra width
Old 07-27-2018, 08:43 AM   #8
That’s the one missing. Banggood has some showing but not in stock. If/when they ever get any I’ll be getting 5+ sets.
Old 07-27-2018, 12:15 PM   #9
Maybe some 3D printed hexes? Would be a super quick/easy design....
JSterrett is offline   Reply With Quote
Old 07-27-2018, 12:42 PM   #10
Otho g on Shapeways that popped up by searching through the RC 1/24 category.
Old 07-27-2018, 02:26 PM   #11
You can find anything on Amazon I'm finding. Their RC stuff changes almost hourly with the way Fulfillment by Amazon works. I got some 8mm hexes earlier this week from Amazon. Here is a replacement part for a WL vehicle, looks almost exactly the same as the 8mm's I just ordered.
https://www.amazon.com/DiDi-iRC-Alum...=7mm+wheel+hex
jwwolf3 is offline   Reply With Quote
Old 07-27-2018, 02:44 PM   #12
Those are 7mm thick and a 12mm hex. Looked at them, too.
Old 07-27-2018, 03:22 PM   #13
I’ve got a mini lathe. If I could only find some hex stock in nylon, delrin, or some hard plastic.
Old 07-27-2018, 08:34 PM   #14
Measuring the couple of hexes I have on hand they are exactly 7mm across flat to flat. Duh? The ID is nearly 4mm where the axle passes through. So after scratching my head I happened across some plastic computer standoffs. 7mm hex and an m4 thread. An m4 hole to be tapped out needs to start as 3.4544mm.
So my thinking is I can cut them to length and then make a notch for the axle pin.
https://rover.ebay.com/rover/0/0/0?m...2F172854619071
Old 07-27-2018, 08:47 PM   #15
I was going to suggest the same thing, hex bar stock would even work, but the stand offs make it easier to drill the center open
Old 07-27-2018, 08:57 PM   #16
I haven’t calipered the axle shaft yet. But I think the standoffs may slip on very snugly.
Old 07-30-2018, 08:51 AM   #17
Uh.. Are you sure the product I linked is a 12mm hub? In the Q&A there are two responses specifying outside diameter is 7mm rather than 12mm, and I definitely ordered an 8mm set from the same source w/o any issues.
Old 07-30-2018, 09:07 AM   #18
I was wrong. I assUmed that since these were mostly monster truck looking RCs that they used a 12mm. This link shows them as 6mm but usually their measurements are wrong anyway.
https://www.banggood.com/Wltoys-A949...-p-957332.html
Old 08-02-2018, 11:44 AM   #19
Look into basher rocksta.hobby king.they work on trekker axles
1tuffmj is offline   Reply With Quote
Old 08-11-2018, 01:30 PM   #20
The standoffs came in the mail today. I dug out my year old micro lathe that’s never been used and fired it up. The standoffs I ordered were medium length of the ones offered and I was hoping to get 3-4 off of one, but these don’t pass all the way through.
I can only get two per standoff due to the center being solid.
Trekker on the lower right. Any recommendations for cutting a pin groove? I’m thing of just chucking a little bur bit from my Dremel into the lathe and work it that way. Better to have one end stationary than both sides moving.
Wheel hex source...? - Similar Threads
2-56" x 1/8" Hex Head Bolts anyone have a source? Dostradamas Tires and Wheels 6 04-14-2013 08:56 AM
Wheel with no hex? Terranaut Tires and Wheels 14 03-17-2010 11:41 AM
Taking hex out of wheel without damaging wheel? bi_eep Newbie General 8 03-06-2008 05:58 PM
Another Source Of Wheel Weights ($.33/oz) Robb Tools, and Procedures 1 02-23-2008 06:29 AM
