Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Lengthening SCX24
Old 10-02-2019, 11:48 AM   #1
Default Lengthening SCX24
I briefly saw this talked about in 1 post, but nothing more concrete. What are the extra links and half shaft for that came with the SCX24? I believe someone said they were to make it longer. Which end? And where?
Thanks.
jimbo74 is offline   Reply With Quote
Old 10-02-2019, 11:54 AM   #2
Default Re: Lengthening SCX24
They are to shorten the wheelbase. I forget the exact numbers, but a few mm longer than a Barrage. Closer to the Carisma MSA1-E
Sent from my Pixel 3 XL using Tapatalk
spoo76 is offline   Reply With Quote
Old 10-02-2019, 12:08 PM   #3
Is it in the manual?
Brake Weight is offline   Reply With Quote
Old 10-02-2019, 12:18 PM   #4
I don't remember seeing it, but it's been a while since I've looked in it
Old 01-12-2020, 09:31 PM   #5
Ok, so.... I just got the longer links. Someone told me my rear end of the deadbolt is already longer? But the kit I can use in the front to make it longer?
I have the Deadbolt
Old 01-13-2020, 05:40 AM   #6
Let me 3D Print that...
RexRacer19's Avatar
If you have the Deadbolt and bought the links for the Jeep, you can stretch the front wheelbase by 10mm. You need the links for the Jeep in order to get the longer upper Y link unless you are planning on doing the 4-link mod which will require custom links anyway. You will need to make the front driveshaft longer as well.
RexRacer19 is offline   Reply With Quote
Old 01-13-2020, 05:51 AM   #7
I did get the whole kit. It does make it way longer. To the point my servo hits the bumper.
Old 01-13-2020, 10:28 AM   #8
RexRacer19's Avatar
Yes. Everything is packaged pretty tight up front. Moving stuff around usually requires modifying something.
Old 01-13-2020, 12:14 PM   #9
I put it back the way I had it.
Old 01-13-2020, 01:15 PM   #10
It's possible you need the Jeep JL front bumper, as the upper shock mounts seem to be made into it. I'm not certain what the differences are, but I'd be willing to bet that's part of it. I ordered the JL front bumper, lengthening kit, and rear bumper w/ hinge. Should have it sometime next week so I can comment then.
Also, it may be time for someone to design a chassis mount for the servo.
Sh0rtBus is offline   Reply With Quote
Old 01-13-2020, 01:41 PM   #11
one thing I did notice, is the ES09md is longer in body. so even in a stock mount, it is very far forward.... does the shapeways mount move the back of the servo further back over the pumpkin, or does it make it stick so far out?
Old 01-13-2020, 02:04 PM   #12
RexRacer19's Avatar
The one I sell for the Micro Shark conversion pushes it back a couple of mm. That is designed for the ES08 though. Not sure how the ES09 compares dimensionaly.
Old 01-13-2020, 05:28 PM   #13
they are pretty close if I remember correctly
Lengthening SCX24 - Similar Threads
Lengthening the wheelbase AreCee Axial SCX-10 15 08-21-2009 08:25 PM
slash wb lengthening? 0778drz110 Non Crawler RC's 23 07-02-2008 10:45 AM
XC lengthening tut?? waluu Newbie General 2 05-21-2008 09:50 AM
chassis lengthening firstumustcrawl General Crawlers 7 07-20-2004 06:22 PM
Lengthening a TXT ultralord Tamiya Txt-1 and Juggernaut 12 05-23-2004 11:02 PM
