10-15-2019, 04:49 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: NorCal
| Emax es09md
Anyone running this servo? Looks to be within 1mm of size to the es08, but stronger, and digital instead of analog.
10-16-2019, 09:36 AM | #2 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Emax es09md
Looks like it might fit, case dimensions do appear almost identical to the 08ii. You might have guinea pig it for us.. |
11-23-2019, 11:27 PM | #3 |
| Re: Emax es09md
so....... no one?
11-25-2019, 04:34 PM | #4 |
| Re: Emax es09md
Anyone know if the fact it is digital will matter? I know some radios won't play well with digital stuff. Or vice versa
12-01-2019, 06:03 PM | #5 | |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Emax es09md Quote:
Using a savox servo in that, it would toggle from left middle right just fine. The EM08 analog ones also did not like the flysky GT5 4WS receiver. It would jump around when I would switch the 4WS mode (on, off, crab, etc). They do work fine with a signal reverser though. Strong little servos. But not electronics friendly IMO. | |
12-01-2019, 07:18 PM | #6 | |
12-01-2019, 08:21 PM | #7 |
| Re: Emax es09md Well, I would try the digital. Dont get me wrong. The analog one works fine for normal single use. They just didnt like being used in the AUX port if you were going for 4WS. They didnt like my GT5 receiver with 4WS setup either. Those are the only two limitations I ran into with mine. I also tried a savox digital one and it worked fine in the AUX port and with the flysky GT5 in 4WS setup. So if I was going to order one, I would probably try the digital. In fact, I kind of want too now! |
12-02-2019, 06:37 PM | #8 |
Newbie Join Date: Jun 2017 Location: The Bay
| Re: Emax es09md
I just ordered an ES09MD, I'll get back to you in two weeks to see if it fits lol. It has nearly the same measurements as ES08 so a bit of shaving should be enough. I'll have the Shapeways ES08 mount too.
12-02-2019, 08:52 PM | #9 | |
Shapeways is doing a sale right now | |
12-08-2019, 08:30 PM | #10 |
| Re: Emax es09md
Did you get it yet? Haha, I know it has only been 6 days, but I'm impatient.
12-09-2019, 04:31 PM | #11 |
| Re: Emax es09md The eBay seller still hasn’t shipped the servo. I sent them a message two days ago and they haven’t responded. Bad luck I guess. I’ll get a refund if they don’t respond again and order from a different seller. Sorry.
12-10-2019, 12:08 AM | #12 |
| Re: Emax es09md
Was it coming from China?
12-10-2019, 06:00 PM | #13 |
| Re: Emax es09md |
12-10-2019, 06:40 PM | #14 |
| Re: Emax es09md
Bummer guys. Once mine goes out, that will be the one I buy next.
12-11-2019, 06:42 AM | #15 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: Emax es09md
The only concern I have with the ES09D is that it doesn't have metal gears. Does it really need it? Maybe not. But for me at least, I'd rather not have that as a weak link in the build. Since it's a micro, I doubt there's much advantage in running a digital servo vs an analog. But of course I'll be the first to say I could be wrong.
12-11-2019, 11:10 AM | #16 | |
https://rover.ebay.com/rover/0/0/0?m...2F173414827140 | |
12-11-2019, 11:10 AM | #17 | |
Thank you for mentioning that. I almost bought 2 just to try digital over the analog I have. | |
12-11-2019, 11:11 AM | #18 | |
| Re: Emax es09md Quote: There we go! Boom! | |
12-14-2019, 01:07 AM | #19 |
| Re: Emax es09md
well, I ordered one....
12-14-2019, 11:20 PM | #20 |
| Re: Emax es09md
Says my servo has shipped usps and should be here friday
Emax es09md - Similar Threads | ||||
Emax trans in scale basher/crawler? | codycr6 | General Scale Talk | 16 | 07-21-2006 07:37 AM |
