Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: TAT's Micro Journey
Old 12-03-2020, 07:07 AM   #1
Default TAT's Micro Journey
In preps of the long coming winter boredom I've decided to jump into the micro crawler world in hopes to have small gatherings run trucks on my diy course. Building mobile terrain is new to be but with help from others I got a good start.
Trucks: B17 on order but do to release being unknown, yesterday I ordered the yellow scx24 jeep.
Course: I plan to build 3- 2x4 platforms that will match up to make a 4x6 micro terrain fun run.
Sent from my SM-G975U using Tapatalk
TAT76 is offline   Reply With Quote
Old 12-03-2020, 08:45 AM   #2
Default Re: TAT's Micro Journey
That's looking good. Can't wait to see the next section.
Gramps is offline   Reply With Quote
Old 12-03-2020, 10:27 AM   #3
Excellent!
Shape_Shifter is offline   Reply With Quote
Old 12-03-2020, 11:24 AM   #4
Nice, that looks awesome!
Did you just use larger sheets of plaster cloth? Looks super good.
Turncoat Tony is offline   Reply With Quote
Old 12-03-2020, 11:59 AM   #5
Thanks guys, its been a fun project so far. Going to add another layer to some areas and then on to paint. While painting ill start my second section as painting will take time to do.
I used rolls and just cut it to what I needed. 6 inches I found to work best.
Old 12-04-2020, 08:33 AM   #6
What exactly is plaster cloth? Is it just any cloth material dipped in plaster of paris or is there a specific type of cloth?
Old 12-04-2020, 10:01 AM   #7
It's just plaster coated cloth, you can buy rolls of them from craft and hobby stores. ~10 dollars a roll from a brick and motar, 5-7 dollars online depending where you're shopping.
I'm assuming USD for prices.
Last edited by Turncoat Tony; 12-04-2020 at 10:02 AM. Reason: Spelling and grammar, it's early.
Old 12-04-2020, 06:26 PM   #8
Mine i got off Amazon and its more like a mesh with plaster. You get it wet and lay over what you want. Works great but you need to layer or you'll see the holes, atleast some of mine do.
Got some paint done so I did some poser shots.
Old 12-07-2020, 05:19 PM   #9
Bee jeep showed today so I ran a few laps. Its definitely a better rig then the borrowed micro but still was challenging to make the course.
I'm excited to do more testing, make some changes and continue on my second part of the course.
Old 12-07-2020, 07:03 PM   #10
Course looks good with the yeller Jeep crawling on it. May I suggest that you order a emax servo for it. The one in my Jeep crapped out on the 2nd battery pack. That will also add a bit of weight over the axle. Hope you enjoy yours as much as I do mine.
Be very very careful the SCX24's have a way of multiplying. Started with the C10 now have one of each.
Old 12-07-2020, 07:53 PM   #11
I've been following your threads and have an emax in my cart with a few other parts but am holding out as I like to run stock to have a base feel for the rig.
Well I started with the b17 pre-order and now have ol yellow.. lol 2 before I got the first isn't a good start for an addict.
Old 12-08-2020, 08:43 PM   #12
Section 2: The Compound is laid out and ready for the next step. I feel it will be a nice section coming off the first cliff terrain to a flat man made course. ;)
Old 12-09-2020, 09:15 AM   #13
Looking good, you're going to have a nice little course when you get done.
Old 12-09-2020, 10:55 AM   #14
Thank you! I hope it all works out once its together but the testing I've done sure is fun. Lol
Old 12-11-2020, 06:15 AM   #15
Got to test the 2 section as 1 after work yesterday. Lots of fun was had and they linked together nicely. Some difficult spots that will test your skills and with the tight turns you have to plan ahead.
Lots to do before finished but happy with how they work.
Old 12-11-2020, 09:31 AM   #16
That's an interesting layout you came up with, I like it. If you wet your fingers and rub over the plaster cloth while it's wet you can fill in alot of the voids where the cloth shows. I wet my cloth in a rubbermaid type container. I have also taken a 1" paint brush and used the liquid from wetting the cloth of cover spots where the cloth shows. Haven't tried this yet, you can get colored sanded grout at the hardware store. Mix it like paint, would add strength, texture, & color all at the same time. I'm thinking of trying it on the section on top of the frig.
Old 12-11-2020, 02:16 PM   #17
Hey thanks for the tips. I thought the mesh cloth would give it more grip so I didn't take that extra step. Not sure it really helped any but I do like how it turned out. Still have areas that need attention but trying to get the 3 sections covered as thats the messy part.
Old 12-11-2020, 08:11 PM   #18
The see-saw is awesome!
Old 12-11-2020, 08:49 PM   #19
They also make terrain molds for the cloth that are reusable to make rocks, hills, ect. And they have this wrap stuff that's almost like a fine grit sand paper that lays over what you want. I found it in the back of my LHS it's mainly sold for the train layout people but I think it would be a great use for micro courses as well. I'm planning on trying it out after Christmas.
Sent from my Pixel 3 XL using Tapatalk
mitch.douglas21 is offline   Reply With Quote
Old 12-12-2020, 06:03 AM   #20
It's pretty getto honestly and I should have taken more time but it's different so I'll rock it till it breaks.
Good to know, I'll go over and see if I can find some today. I've been thinking of a way to make rock/cliff forms for my stairs, Could make an awesome climb..
TAT's Micro Journey - Similar Threads
Journey of SMP TAT76 Axial SCX10 II 57 03-08-2021 06:08 AM
My trx-4 journey dittohead Traxxas TRX-4 6 08-05-2017 10:42 PM
A Journey with Traxxas Summit Straffa Videos! 1 06-03-2012 04:23 PM
I seen Journey last night... Kamikaze Chit Chat 8 08-09-2008 01:47 AM
