03-23-2021, 06:01 PM | #1 |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
| Scx24 C10 Furitek and Surpass brushless outrunner |
03-24-2021, 08:40 AM | #2 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Scx24 C10 Furitek and Surpass brushless outrunner
I like the surpass slow speed ALOT. But I am bummed I cant get it super muddy. I got a dam bolt stuck in mine once already. Man that was a real pain to find and get out of the bell housing. I was removing the tranny and the top bolt just magnet flew right into it...lol.
03-24-2021, 12:32 PM | #3 | |
Newbie Join Date: Mar 2021 Location: USA
| Re: Scx24 C10 Furitek and Surpass brushless outrunner Quote:
I was wondering about those openings in the motor. Don't suppose you'd want to cover them either since they are for cooling I guess? | |
03-24-2021, 02:53 PM | #4 | |
That lil screw immediately sucked into it at Mach 5 speed. Im note sure. It doesn't even get luke warm to the touch though. Maybe I can condom mine up... Just slap one up and over the bell housing and see what happens. The only other issue with the surpass is the drive shaft. Depending on what pinion you use (at least with the reverse mount version), limits your drive shaft choices. I run a 15T right now and my bell housing is like 1mm away from rubbing against the rear drive shaft union out of the transmission. I have a thicker than stock all metal drive shaft(not the HR ones) that will rub if I use anything smaller than a 15T pinion. But even with the 15T pinion, its super slow. | |
03-28-2021, 08:44 PM | #5 |
I got my Furitek TEGU! Man, what a cool little ESC! I was using a mamba micro X, but it was very loud with the surpass motor. This little furitek tegu ESC is dead quiet and the bluetooth app has SO much you can tweak! This really is the best ESC for any micro IMO. Also, this one will move and keep torque up high even moving 1mm a minute. You cant almost think its not moving when it is moving, its that slow. Well worth the investment! WELL WORTH IT! |
03-29-2021, 10:25 AM | #6 |
Pebble Pounder Join Date: Aug 2020 Location: Ohio
The clearance from the motor to the drive shaft can be a problem. I have noticed it using GamyRC's LCG mount with 11T pinions. When I use 12T the problem when away. There are other mounts available. Gamy's LCG was a change from his centered, and slightly higher version. I do not know if he still has that version available. Dustin Bailey also makes several versions of the Surpass mount. I think he has a version that moved the motor to the other side of the gearbox. Dustin's page: https://www.ebay.com/usr/dirtyscustoms The brushless upgrade kits that I offer come with Gamy's LCG mount and a 12T pinion. |
03-29-2021, 10:29 AM | #7 | |
I have larger drive shafts on my mine with his motor mount and I can still get down to an 12T. I like 14T myself though. Last edited by BIGW0RM; 03-29-2021 at 10:48 AM. | |
04-08-2021, 12:30 PM | #8 |
| Re: Scx24 C10 Furitek and Surpass brushless outrunner |
04-17-2021, 05:20 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
Hey guys, what settings do you use to make the slow-to-fast transition smooth out? I fiddled with the throttle curve and the break point between crawl and jam is still abrupt, and punctuated with a slight cog. Any ideas?
04-18-2021, 09:52 AM | #10 | |
Mine did that too. I made my throttle curve very low to about 80% before it ramps up. That way my low speed had a much wider band before it crossed over to boost which is the 3rd dot on the throttle chart. Seems that once you hit the 3rd dot, boost kicks in. FOC is 10 . Punch is set to 1 Start up power is LOW Those setting on mine work great. Good luck! Sent from my iPhone using Tapatalk Last edited by BIGW0RM; 04-20-2021 at 05:57 PM. | |
01-26-2022, 02:35 AM | #11 | |
Pebble Pounder Join Date: Nov 2021 Location: Finland
Scx24 C10 Furitek and Surpass brushless outrunner - Similar Threads | ||||
Furitek Lizard esc + 8000kv = one sick scx24 | Unclelee | Micro Scale Rigs | 18 | 02-04-2022 12:05 PM |
C10 SCX24 in the woods | waqr | Videos! | 0 | 05-23-2020 11:40 PM |
SCX24 C10 Body | DJJorel | Micro Scale Rigs | 3 | 05-20-2020 05:49 PM |
Scx24 c10 | JMHZ2401 | Micro Scale Rigs | 0 | 04-03-2020 08:04 PM |
