01-17-2023, 01:50 PM | #1 |
Pebble Pounder Join Date: Feb 2022 Location: Brooklyn
| YNAD's 6x6
Started as a parts bin build. Now it's a 180 motor + brass links crawl monster Rcawd transmission with the 180 motor, SCX24 axles, injora brass links(gladiator middle, c10 front links far rear and front) FCX24 body, some fms model front bumper. Now onto full interior, roll cage, accessories. Sent from my LG-V521 using Tapatalk Last edited by Ynad; 01-17-2023 at 02:13 PM. |
01-17-2023, 03:43 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: YNAD's 6x6
That is sweet!!! What did you use for the chassis extension? |
01-17-2023, 04:33 PM | #3 |
| Re: YNAD's 6x6
Thank you. Scratch built from brass stock. I'll get pics of it soon. Sent from my LG-V521 using Tapatalk |
01-18-2023, 01:10 PM | #4 |
| Re: YNAD's 6x6
Not to difficult to fabricate. 80mm extension, 20mm link mount. Two sizes of brass stock used, telescoping sizes. I also used shocks tower replacement as the links mount. Cut plastic stock one to size for the 3rd drive shaft. Sent from my LG-V521 using Tapatalk |
01-18-2023, 02:14 PM | #5 |
| Re: YNAD's 6x6
I had no idea how much fun this thing could be! First run out on the real rocks revealed pros and cons. It's very powerful, not fast but goes through everything. It is heavy. Was hoping brass links would be good enough of weight down. But it is still top heavy with the 180 motor. Gotta figure out how to keep it from tipping over. Most of the glass in the cab is removed and there is very little of the interior, unnecessary plastic is removed from the dashboard and seats. Doesn't like side hill but can go up at a ridiculous angle. And I took it too far. Love the real trail damage. Screw on steering link came undone some and then got bent and ripped out. Sent from my LG-V521 using Tapatalk Last edited by Ynad; 01-18-2023 at 02:20 PM. |
01-18-2023, 04:24 PM | #6 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Re: YNAD's 6x6
That's a nice looking rig. If you replaced the brass frame rails and the other high up brass with aluminum I would think it would lower the CG a bunch. Might help too if you could get the battery lower. Maybe put a tool box where the battery is and mount the ESC & Rx in it and out the battery in the cab. Don't have any micro 6x6's but do have a TRX6 that is fun to crawl. Pretty amazing what they can do. |
01-18-2023, 07:39 PM | #7 |
| Re: YNAD's 6x6
Thank you Gramps. Good points. I'll look for the aluminum equivalent. May be drop the idea of an interior and move battery in the cab. Sent from my LG-V521 using Tapatalk |
01-19-2023, 09:23 AM | #8 |
| Re: YNAD's 6x6
Maybe a smaller battery I have some whoop batteries that are shaped more like a pack of gum that are 2S and 350-550 mah. Also have a real small Nano-Tech but I forget it's mah but I think it's 300
01-21-2023, 03:09 PM | #9 |
| Re: YNAD's 6x6
Thank you Gramps for your suggestions. It is helpful to stir the thought process. Ended up with the smaller battery fms 380mah is the perfect size for space above the front axle in front of the motor. Plus, spaced out front wheels few mm, I still want to keep the rear narrow. It is good now. Amount of drag brake is unbelievable. This combo 3 axle and the big motor keeps it still at any angle, no roll at all. Sent from my LG-V521 using Tapatalk |
01-22-2023, 04:12 AM | #10 |
Rock Stacker Join Date: May 2015 Location: North Lakes, QLD
| Re: YNAD's 6x6
I built this with the Meus kit, basically an extended LCG chassis. I have a long way to go with the shock tuning as the rear is pretty light, currently running no springs and way overdamped in the rear but it was it's first real run out and it will change. waiting for matching tyres, they will also be "backwards" :P |
01-22-2023, 02:42 PM | #11 |
| Re: YNAD's 6x6
Good looking rig. What shocks are those? Sent from my LG-V521 using Tapatalk |
01-23-2023, 02:52 AM | #12 |
Pebble Pounder Join Date: Nov 2021 Location: Finland
| Re: YNAD's 6x6
They look a lot like the injora oil filled shocks.
01-23-2023, 04:57 AM | #13 | |
| Re: YNAD's 6x6 Quote:
They are great shocks when you remove the plastic spacer between the two orings in the lower seal. Not as much flex as the facebook crowd like to run but they actually allow tuning and don't leak (I have 2 sets of 4 and one set of 6). | |
01-23-2023, 01:44 PM | #14 |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
| Re: YNAD's 6x6
Thanks for posting about removing that spacer. I had loosened those bottom caps but it would still stick every now and again. They seem like great shocks otherwise
01-24-2023, 04:52 AM | #15 |
| Re: YNAD's 6x6
Great info. Thank you Sent from my LG-V521 using Tapatalk |
02-06-2023, 11:24 AM | #16 |
| Re: YNAD's 6x6
Some update on the project. Still playing with the battery placement. Seems this one is the last option. Clear plastic box fits too nicely and plenty of room for different sizes of the batteries. Also some cheap light controller. Good thing- back up lights. Stupid thing - head light go on when moving forward only. It comes with the turn signals and clicking sound for turning. Quick fix: keep nice amber lights, kill the speaker. Looks are getting improvement. Face change. Lazy quick paint job inspired by the red on the body it had. It's gonna get messed up anyway. But now it matches my green fleet. Added some interior and the roll cage. Testing some bed options. Articulation of the axle wont allow for wider bed unless it's placed higher, and higher is not good. So narrow it is. Now if only I could figure out how to get the exoskeleton roll cage like the trail trial trucks. Currently on a look out for the source toys... Sent from my LG-V521 using Tapatalk Last edited by Ynad; 02-06-2023 at 11:26 AM. |
02-06-2023, 01:40 PM | #17 |
| Re: YNAD's 6x6
Looking excellent bro. I am having trouble choosing a bed/body to stick with. I changed the rear links on mine to JLU fronts and put on 62mm tyres, probably going to change back but it looks pretty cool.
02-06-2023, 03:08 PM | #18 |
| Re: YNAD's 6x6
I'm liking the weathered look on the body
02-07-2023, 11:16 AM | #19 |
| Re: YNAD's 6x6
That's what I got on it right now. C10/FLU front and far back, gladiator rears in the middle. 62mm tires. FMS "atlas" has the bed suitable for these. But might be too wide. Very easy weathering pat job. Coat of black, rub off some with paper towel while wet. Let dry. Repeat process with the green. Silver accents are some nail polish with brushed on diluted in solvent black paint. Satin clearcoat. Thank you guys for the comments. Sent from my LG-V521 using Tapatalk Last edited by Ynad; 02-07-2023 at 11:26 AM. |
03-19-2024, 06:22 AM | #20 |
| Re: YNAD's 6x6
Updated this thing. Now it's unstoppable. Behind the axle steering, rear steer. DinkyRC esc. Agustable upper front links for better angle not axle. Sent from my LG-V521 using Tapatalk Last edited by Ynad; 03-19-2024 at 06:25 AM. |
YNAD's 6x6 - Similar Threads | ||||
Ynad's TRX4M + mods. Updated 5/03 winch, lift, bumper, hitch, sway bsrs | Ynad | Micro Scale Rigs | 33 | 05-15-2023 03:01 PM |
My HG601 6x6 aka The Dubsta 6x6 | W1ck3d0n3 | Multi Axle Rigs | 5 | 12-21-2020 02:17 AM |
Another SUX 10 based 6x6 Traptor build, named Texas Pete. And it's not 6x6 yet, I ran | tcanin00 | Multi Axle Rigs | 11 | 05-26-2019 04:49 PM |
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** | dankycrawler | Multi Axle Rigs | 37 | 04-18-2013 02:09 PM |
6x6 | rockoff | Tamiya Clod Buster | 5 | 01-18-2013 04:05 PM |
