02-15-2023, 08:23 PM | #1 |
Quarry Creeper Join Date: Mar 2014 Location: LI
| “Hurricane Sandy” build thread.
I picked up a SCX24 a while back and have just been crawling around the living room with it for a while. Eventually got the bug to start doing some things to it. To date: it’s a mostly stock Deadbolt with Wrangler MTRs, and beadlock wheels. The other day I added a 4 link from Injora, and I have some 48mm shocks on order. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-16-2023 at 04:18 AM. |
02-15-2023, 08:29 PM | #2 |
| Re: “Hurricane Sandy” build thread.
I also ordered a Lindberg 1/20 Syclone model from eBay. That arrived today and I did a quick mock up. Basically just layed the body on top to see what the wheelbase looks like unmodified. Sent from my iPhone using Tapatalk |
02-16-2023, 07:45 PM | #3 |
Pebble Pounder Join Date: Feb 2022 Location: Brooklyn
Looks like the beginning of the beautiful friendship. Sent from my LG-V521 using Tapatalk |
02-16-2023, 08:15 PM | #4 |
Put a few pieces of the truck together and got a bit closer to ride height for the body. I feel like it should be lower though. I know I’m gonna have to blast out those fenders with a dremel to get it down a bit more. That gives me a bit of anxiety I think before I go any further with mounting the body I’ll install a new servo and get the battery and esc placement sorted out. Sent from my iPhone using Tapatalk |
02-17-2023, 05:35 PM | #5 |
Well, everything is on hold now because I made an impulse purchase of a MOFO chassis last night. Sent from my iPhone using Tapatalk |
02-18-2023, 02:41 AM | #6 |
Pebble Pounder Join Date: Nov 2021 Location: Finland
That’s a good looking body! If you don’t wanna ruin it, there are also longer shocks. (also remember telescopic shocks are good for light bodies). I’ve tried a lot of shocks, and I really like the injora oil shocks. They don’t leak! and a lot of folks think they are too stiff, but if you only insert a tiny bit of oil and check that there isn’t any bubbles in the oil they work fine. I’ll admit it took some time to get them to work really good. But after that I’ve been really happy with them. Don’t bother with the fcx24 oil shocks, they leak. A lot. |
02-18-2023, 06:31 PM | #7 | |
| Re: “Hurricane Sandy” build thread. Quote:
Thanks for the suggestions. For now I have some cheap eBay 48mm shocks that just came today. I don’t mind cutting the body, I just get nervous about doing it. I’ve gotten pretty good with the dremel so I have to just get over the initial hesitancy of cutting up a perfect body lol. I’ll likely run them with no springs, or maybe the stock springs. I’m a sucker for the low mounted truggy look. Sent from my iPhone using Tapatalk | |
02-21-2023, 07:09 PM | #8 |
Mofo chassis should be here tomorrow. Shocks arrived as well. Probably run then without springs or maybe the stock springs. Installed new servo. Likely going to continue build as a truggy with the Mofo chassis. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-21-2023 at 07:11 PM. |
02-21-2023, 07:11 PM | #9 |
Something like this but with the Mofo chassis Sent from my iPhone using Tapatalk |
02-22-2023, 08:35 PM | #10 |
MOFO Ugly ASF aluminum chassis installed. Very happy with it so far. Went together nice and easy. Lots of extra screws which is always good. The weight forward is absolutely killer. Just crawling around in the couch and I can notice a massive improvement. These crappy eBay shocks are killing me though. They are not very smooth at all. They get stuck closed, they get stuck extended. I guess that’s my fault though, should have went with something better. I thought about stretching the front a bit but I’m kind of happy with the wheelbase for now. Next to do is chop up the truck cab and get it fitted. Sent from my iPhone using Tapatalk Last edited by KBR97; 02-22-2023 at 08:37 PM. |
02-22-2023, 09:34 PM | #11 |
If I wanted to stretch the front a little bit what links should I use? C10 I’m guessing Sent from my iPhone using Tapatalk Last edited by KBR97; 02-22-2023 at 09:44 PM. |
02-23-2023, 08:28 PM | #12 |
Little by little I’ve been working on this. Today I worked out some binding issues by removing one O-ring from each shock and link. Then I got over my anxiety and starting cutting up the hardbody GMC cab. Got the fit on the rear set up and then finished up one wheel well opening. Sent from my iPhone using Tapatalk |
02-26-2023, 11:18 AM | #13 |
Just a quick update. Got the hood and grill glued together. Cut the stock esc tray and used it as a magnet mount. And made a limiting strap from a random piece of cloth strap. Tied it around the top of the battery tray and the top of the 4 link center mount on the servo. Also received a package via FedEx this morning. Sent from my iPhone using Tapatalk |
02-26-2023, 04:11 PM | #14 |
Some photos from a quick run by the lake. Sent from my iPhone using Tapatalk |
02-26-2023, 07:26 PM | #15 |
Torquebeast 50 on the way! Sent from my iPhone using Tapatalk |
“Hurricane Sandy” build thread. - Similar Threads | ||||
RIP Sandy | Greatscott | Chit Chat | 4 | 08-09-2022 06:53 AM |
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
Sandy | RANOVRU | Chit Chat | 99 | 11-02-2012 10:12 PM |
Jeep Hurricane Build | DANALLY | Losi Micro-Rock Crawler | 19 | 06-27-2012 05:05 PM |
