06-07-2023, 04:27 PM | #1 |
Quarry Creeper Join Date: Apr 2023 Location: NW Connecticut
| A SCX24 JLU hardbody build for the wife .
Racent body fitted to SCX24 chassis . Purple Treal wheels , purple Treal steering links , purple Hotstorm links and 43mm shocks , Injora 050 pro motor , bumpers , brass knuckles , 57mm rock terrains , 10g brass front diff cover and tire carrier . RCAWD rear bumper/hinge mount . Powerhobby +4mm axles .
06-07-2023, 06:41 PM | #2 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
| Re: A SCX24 JLU hardbody build for the wife .
I really dig that ano purple with the white body and black accents. Really looks killer and nice flex too.
06-07-2023, 08:12 PM | #3 |
| Re: A SCX24 JLU hardbody build for the wife . Her favorite color is purple , I think it needs to be lowered a few mm , she likes the lifted look . A few details on the body need to be painted black to match her Jeep . Lights will be wired soon .
06-08-2023, 08:29 AM | #4 |
Rock Stacker Join Date: Oct 2014 Location: Raeford
Looks good
06-08-2023, 12:18 PM | #5 |
Pebble Pounder Join Date: May 2023 Location: SW Ont.
Good looking Hardbody, do you have the link for it?
06-08-2023, 03:20 PM | #6 |
| Re: A SCX24 JLU hardbody build for the wife . https://www.exhobby.com/collections/racent It’s a cheap SCX24 clone . You can purchase just the body , I think there’s 3 colors available. |
06-08-2023, 03:49 PM | #7 |
All I did to mount the body was install it with the mount hinge X piece on the outside of the body in the rear , covered it with a spare tire carrier, Velcro on the front mount . There is a knob for a spare on the Racent body , that was dremmeled down . I used the Racent spare tire . I used an aluminum RCAWD rear hinge and dremmeled that a bit to make it flat . I am very happy it was an easy install. The tires sit perfect in the wheel wells . |
06-08-2023, 05:28 PM | #8 |
A few photos of the mounting modifications. If the hinge was in the normal position the rear tires would rub on the front of the rear fender flair . I could probably mount the body lower also but the wife likes the lifted look .
06-08-2023, 05:36 PM | #9 |
Bottomed out .
06-08-2023, 05:39 PM | #10 |
Thanks for the link, time to go have a nosey ... cheers.
06-09-2023, 04:12 AM | #11 |
| Re: A SCX24 JLU hardbody build for the wife . |
06-09-2023, 05:00 PM | #12 |
The wife and I took the JLU out for its first trail run today . She drives it like a pro . A Bowhouse LCG kit , Hot Racing heat sink and Yeah racing aluminum front bumper mount was waiting to be installed at home . I had to modify the Bowhouse LCG kit to fit the Injora 50T pro motor and a little more room was desired for the rear shock mounts, I moved the battery to the low forward of the transmission position and the ESC to above the motor. I will be adding more wiring for headlights and taillights so wanted the ESC closer to the rear hinge to run the wires into the body at the hinge point . Installed the heat sink to keep it all cool . I also swapped sides of the rear shocks mounts and mounted the shocks to the body mount Post hole to lower it a bit . I also adjusted the front body post a little lower. |
06-10-2023, 04:00 PM | #13 |
I added 2 Injora light kits for the TRX4M to light things up , the kits fit perfect . Cut up the original battery tray to aid in wire management in the back . I need to find a relay to get them to work on and off with channel 3 .
A SCX24 JLU hardbody build for the wife . - Similar Threads | ||||
Scx24 JLU Drive shaft, Axle Question | Steelone232 | Micro Scale Rigs | 3 | 06-04-2023 02:37 PM |
SCX24 C10 for the Wife | AK KRAWLER | Micro Scale Rigs | 12 | 04-03-2023 10:50 PM |
Giant basement crawler course for SCX24 JLU, RC4WD 1/18 D90, and Mini-Z 4x4 Jimny | karl_toboggan_rc | Micro Scale Rigs | 0 | 08-08-2020 07:22 PM |
SCX24: Deadbolt Vs JLU | KulaHI | Micro Scale Rigs | 13 | 01-08-2020 05:21 PM |
NEW Axial Racing SCX24 2019 Jeep Wrangler JLU CRC RTR - IN STOCK NOW! | RPP Hobby | RPP Hobby | 0 | 11-25-2019 01:06 PM |
