10-24-2009, 12:42 PM | #21 |
Newbie Join Date: Sep 2009 Location: lost in time somewhere near Murphy NC
you got any videos of that thang in action? great job though. it looks cool. i would like to have one for myself.
10-24-2009, 02:07 PM | #22 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
for driving both rear ends .... turn the forward rear axle around and run you shaft carrier bearing style. I don't think the T-case would work for that though but maybe if you flip an axle so it runs reverse then you can run your input shaft to the rear ouput. Then place the 'case where the first driveline would work angle and length wise (using the lowest output shaft). The upper output would run to a 'Carrier bearing' (just a 5mm shaft with two bearings placed right above the first rear axle with the shaft reatined by both shaft yokes) that'll give you reasnable driveshaft lengths and angles. But, as you would be using the original input shaft as the new rear rear axle output, you may need to flip the axle to reverse it's rotation. It'll be a fair bit of shafting, but it'll work, and still allow for adequate suspension movement. Plus, use what you already have with just a little bit more ... as opposed to starting over.
10-26-2009, 07:45 AM | #23 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
10-26-2009, 09:30 AM | #24 | |
RCC Addict Join Date: Jul 2008 Location: Sin City
11-05-2009, 12:22 PM | #25 | |
Pebble Pounder Join Date: Feb 2009 Location: here
11-06-2009, 12:40 AM | #26 |
| Ya its either going to be something like that or something like the pinzgauers where the tcase is in the front and 2 different shafts run back. I need to get back moving on this project, lol.
11-07-2009, 07:29 AM | #27 |
Rock Stacker Join Date: May 2005 Location: West Bend
These 6x6s re great builds!
11-21-2009, 07:42 PM | #28 |
found a body! finally i guess. I got the rear suspension worked out just waiting for some more driveshafts but while surfing fleabay i found.... .... for 99cents. |
11-22-2009, 10:50 AM | #29 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
I have very simaler to that^^^
11-23-2009, 12:54 AM | #30 |
11-28-2009, 12:08 PM | #31 |
No ill post pics of it if you want tho? |
