Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Help please !!
Old 03-24-2018, 01:38 PM   #1
Default Help please !!
Hi all I need a little help please I’d like to build a double drive axle, now I’ve seen folks use the scx10 axles but was wondering would it be possible to use these from the HPI Venture ?
Can it be done oram I missing something ?
mydoddy69 is offline   Reply With Quote
Old 03-24-2018, 01:49 PM   #2
Default Re: Help please !!
It should be similar to any other pass through axle conversion. Get a 3rd axle with a 4th front half that has the output for the pinion gear and assemble.
Now you have an axle with one ring gear, an input and output pinion gear.
However the pass through has the pinion on the wrong side of the ring gear and will spin the last axle the opposite way. You'll need to flip the axle upside down so the bottom is now the top and make new link mounts.
Sent from my LG-M322 using Tapatalk
spoo76 is offline   Reply With Quote
