Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Super Six - Diesel Sellerz F-550 6x6x6 SEMA Tow Rig
Old 08-30-2016, 05:57 AM   #41
Default Re: Super Six - Diesel Sellerz F-550 6x6x6 SEMA Tow Rig
Originally Posted by Polaris425 View Post
That's just freaking sick!!! Love It!
Thanks man!
Originally Posted by Szczerba View Post
Love this truck.
The trailer suspension setup is genius.
Thanks! I was just wandering through the hardware aisle looking to be inspired and this idea popped in my head
Originally Posted by XSRCdesign View Post
Man this is a BIG truck. I like it!
You are pretty good at joining lexan together
Thanks! It's not that bad once you get the hang of it. Plus painting lexan on the outside makes it look so much more realistic. Scratches and such. It does get expensive though unless you have old bodies laying around.
dna4engr is offline   Reply With Quote
Old 08-30-2016, 08:47 AM   #42
I do that as well but have never thought of those rubber pieces for the airbag look. Will have to remember that.
Szczerba is offline   Reply With Quote
Old 08-30-2016, 01:49 PM   #43
I plan on bringing it with to crawlapalooza so if you're there you can check it out with the supersix.
Old 08-30-2016, 09:26 PM   #44
snapon boy's Avatar
That thing is wicked! Can wait to see it.
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Old 08-30-2016, 09:57 PM   #45
What does it look like with the brodizer on the flat deck???????
I'm sure you can guess why I'm asking!! Lol
TRAV is offline   Reply With Quote
Old 09-06-2016, 08:45 PM   #46
Subscribed!
Bulldog is offline   Reply With Quote
Old 09-12-2016, 05:01 AM   #47
Man that thing looks awesome, you should make the Hell Camino next haha
DieselRC is offline   Reply With Quote
Old 09-13-2016, 09:04 PM   #48
Its already been done.
NitroRampage13 is offline   Reply With Quote
Old 09-15-2016, 10:22 PM   #49
Originally Posted by Bulldog View Post
Subscribed!
Thanks boys. It sure is a blast to drive. Only scaler or crawler that I've ever been able to climb an entire flight of stairs with
Moved the front axle back about 3/4". It was about 1/4" too much.
And I took the pro4hd out and put in a 3100kv roc412. Wanted the pro4 for my bomber to get some more top end speed.
Just need to make links and paint the chassis and the rig is ready. The trailer needs some work though.
Old 09-21-2016, 09:16 PM   #50
I finalized the links over the past two nights. I didn't feel like paying for titanium since this is just a fun rig. I had some 5/16" delrin rod. Cut it to length out in set screws and traxxas revo ends and viola
In the process I moved the front axle forward 1/4" and the rear most axle back 3/8". It helps the look and I hope it helps handling when loaded.
Old 09-21-2016, 09:21 PM   #51
snapon boy's Avatar
The delrin will help you to slide over stuff. Good call.
Old 09-26-2016, 10:13 PM   #52
I got a little work done on the trailer tonight.
Gooseneck for the 5th wheel is fabricated.
Now I need to support it with some gussets.
Mocked up.
The Brodozer looks right at home
and it fits 2 rigs like I planned with one axle up on the gooseneck.
Old 09-30-2016, 12:36 PM   #53
Originally Posted by adonis_mp View Post
This is one of the best builds. Great job.
Thanks man I appreciate it!
I made a little more progress on the trailer.
I had to add gusset bars to the goose neck as I'm connecting dissimilar metals and couldn't braze them.
Added some mirrored angle on the sides to create a channel for the wood bed panel.
For connecting to the bed of the #supersix I took some 1/4" al rod and milled out a groove. Then drilled and tapped a hole down the center to attach the "ball" to the bed.
On the hitch party of the goose neck I drilled a small hole to the side that I put a body pin through. The body pin rides in the groove and keeps the trailer from lifting off over bumps. To carry the load I just drilled and tapped a hole in the same tube and screwed in an m3x8 screw that rides on the top of the hitch ball.
I laid down a couple coats of poly on the wood floor to protect it while I finish the trailer up.
Old 09-30-2016, 04:52 PM   #54
A little practice run...driving 1 handed ;)
Old 10-09-2016, 08:21 PM   #55
Where did you get the rubbers for the suspension
Sent from my SM-T813 using Tapatalk
adonis_mp is offline   Reply With Quote
Old 10-09-2016, 08:29 PM   #56
snapon boy's Avatar
He's at crawlapolaza! I saw this thing run wow is all I could say
Old 10-09-2016, 11:22 PM   #57
Either Home Depot or menards. Can't remember exactly
Old 10-10-2016, 08:54 AM   #58
This is great, the show is awesome!! Nice build!!
Sent from my VS810PP using Tapatalk
dkchance74 is offline   Reply With Quote
Super Six - Diesel Sellerz F-550 6x6x6 SEMA Tow Rig - Similar Threads
f350 tow truck/ tow rig bbnate804 1.9 Scale Rigs 13 11-19-2012 07:15 PM
Diesel Wraith Tow Truck scottanthony Scale Videos! 4 07-11-2012 11:06 AM
Diesel Wraith Tow Truck scottanthony Axial Wraith 9 07-04-2012 09:45 AM
