05-03-2021, 06:35 AM | #21 |
| Re: Robotboy's GSpeed 6X6 Mofo
Great work on the body, that looks fantastic!
05-06-2021, 06:02 PM | #22 | |
RCC Addict Join Date: May 2009 Location: In the warmth!
| Re: Robotboy's GSpeed 6X6 Mofo Quote:
05-06-2021, 06:18 PM | #23 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
This thing looks awesome bro! Totally digging it!!! Once I get my rigs back together. We need to go crawl something! Keep up the great work! |
05-06-2021, 06:29 PM | #24 |
Took it out for a little test yesterday. Another snafu A couple minutes in I saw that all the tires were wobbling. Turns out the bead on the backside of all 6 tires popped out. They were a real pita to bead up in the first place but I thought I had it...nope. The lip on the rear of the wheel is tiny and the tires are wide with fat stiff foams. At a loss for a remedy I reached out to Durok for some suggestions. One of the ideas was to trim the foams on the inside edge. I put the internal ring in the foam and traced it. Then took an outside ring and traced that on the outside. Cut diagonal, with a serrated knife, between the lines. So I did one and the thing mounted as it should. Seems to be tight and ready to go. I just got done doing the rest so hopefully I can give it a real shakedown tomorrow. Fingers are crossed... |
05-06-2021, 07:44 PM | #25 |
RCC Addict Join Date: Mar 2019 Location: Hemet
Nice solution to an annoying problem. I had the same issues with those wheels at first with the stock landmine foams. I’ve since swapped to CI dual stage but I hope this works out Sent from my iPhone using Tapatalk |
05-07-2021, 12:17 PM | #26 |
Pebble Pounder Join Date: Feb 2015 Location: East Bay Area, CA
Looks mean as hell with those tires and the new body!!! |
05-07-2021, 08:24 PM | #27 |
| Re: Robotboy's GSpeed 6X6 Mofo |
05-07-2021, 08:33 PM | #28 |
Got 'er out for a little test run today. Gonna be a fun truck for sure! A smidge more tuning and it's all good. Tires worked out without a hitch or a flat Took a vid for your viewing pleasure... Specs as of now and a new pic: GSpeed 6x6 CF chassis, spacers, elect. trays & laydown servo mount. TGH Panhard Mount & Bowhouse AR45 panhard axle mount. Mofo RC Big Boy 6x6 Trans & Cross RC Transfer case. 32P 54T Spur & 13T Pinion. HH Trailmaster Pro BL 1700kv motor. AR45P axles, brass covers & knuckles, SSD OD gears front. CC Mamba Micro X ESC. SPT 35kg WP servo. CC BEC. Traxxas TRX6 shocks. RC4WD MT Baja Pro X 1.9 Tires. China Beadlocks, added Black Hardware & LURC Acorns. MST J45C Cab, Axial UMG6X6 Bed and Moxoo Cage. Last edited by Robotboy; 09-30-2021 at 02:03 PM. |
Robotboy's GSpeed 6X6 Mofo - Similar Threads | ||||
GSpeed G-6x6 TGH-V3 carbon fiber chassis SavageAF6x6 | savageasflux | Multi Axle Rigs | 34 | 01-05-2022 11:20 PM |
GSpeed G-6x6 Chassis unboxing video | savageasflux | Videos! | 0 | 02-03-2021 02:43 AM |
Broke MoFo scx10 6x6 unimog build | igotit | Axial SCX-10 | 11 | 04-03-2009 08:27 PM |
